Engine mount bolts!!!
Old Dec 12, 2006 | 04:05 PM
farscape1a's Avatar
farscape1a
Default Engine mount bolts!!!
Hey guys! I'm in a bit of a jam. I'm close to being ready to throw my new engine back into the car, but I'm missing the 2 long through bolts that mount the engine brackets to the engine mounts. I went out and got 7/16-14x5" bolts (that's what it looked like), and it doesn't seem quite like a match. The nut is sloppy on the bolt, and the bolt itself is extremely sloppy in the bracket and mount. Any and all help is greatly appreciated. If there is anyone that has a spare set of these bolts, PLEASE, PLEASE PM me. Thanks again!
Old Dec 12, 2006 | 04:37 PM
JAKE's Avatar
JAKE
Could be the bolts you need are metric.
What years is your Vette?
Jake
Old Dec 12, 2006 | 05:27 PM
farscape1a's Avatar
farscape1a
Jake
Hey Jake. The bolts actually aren't metric (at least i can't picture them). The reason why I say that is because the original nut that came off of the original engine mount bolt will thread onto the new bolts I just got with no problem, and the bolts I got are 7/16-14. But again, the nuts are sloppy as hell on the new bolts, and the bolts are even more sloppy in the mounts.
Year is a 1992...
Thanks!
Old Dec 12, 2006 | 06:08 PM
divette's Avatar
divette
#10200097 M12x1.75x80 LT1=L98
Old Dec 12, 2006 | 06:18 PM
farscape1a's Avatar
farscape1a
Hey divette! That's a GM part number, right? Thanks!!! You're awesome!!!
Old Dec 12, 2006 | 06:23 PM
divette's Avatar
divette
What cam you have 383 LT1
Old Dec 12, 2006 | 06:29 PM
farscape1a's Avatar
farscape1a
It's actually a custom cam matched to the head and intake manifold work that was done. The owner of the company asked me to not disclose the specs of the cam, and I'm going to respect his wishes. The only thing I have to say is that it's pretty damn lumpy.
Old Dec 12, 2006 | 09:27 PM
JAKE's Avatar
JAKE
I suspected that might be the case, that they are metric. I know when I changed the rear spring bolts on my 96 to lower the rear they turned out to be metric. SAEs will work, but they are a tad loose.
GM loves to play games with the bolts and nuts.
Jake
Old Dec 13, 2006 | 01:42 AM
cv67's Avatar
cv67
St. Jude Donor '05
Jake
Strange this came up. I went and bought some plated grade 8 bolts for the 67s mounts and they are bit sloppy in there, too. Guess Im going back to see if a metric will be a tighter fit (Metric for a 67? )
Id get the factory bolts, but I just HAD to have pretty hardare
Old Dec 13, 2006 | 01:45 AM
cv67's Avatar
cv67
St. Jude Donor '05
Ever stare these guys in the eye for awhile?
I
Old Dec 14, 2006 | 01:24 AM
farscape1a's Avatar
farscape1a
See, now I find that a bit odd that the Vette's have metric hardware at all. I mean, it's the all American muscle car, right? Why metric hardware? Well, I find it odd...
Old Dec 14, 2006 | 01:28 AM
cv67's Avatar
cv67
St. Jude Donor '05
Ok, got it. May not be the same as L98s, but once you get both sides on they will be tight once you actually drop the motor in. clamshell holes are oblonged a bit, mounts arent. It works. No metric on my USA muscle!
Wouldnt surprise me a bit if the L98 stuff is. Dont get that, its an American car
Old Dec 14, 2006 | 02:01 AM
JAKE's Avatar
JAKE
There are quite a few metric bolts, nuts and screws on the Vette. The more you work on the car, the more you'll find. That's why is necessary to have a decent tool set at hand.
Jake
Old Dec 14, 2006 | 12:51 PM
farscape1a's Avatar
farscape1a
Jake
Hey Jake. I've seen that the Vette's have a lot of metric hardware. Pretty much the entire engine is metric (just finished building a worked 383). I still find it a little weird, but it's something that I've gotten used to. Besides, all of my other cars are metric, so visually I've gotten pretty good at guessing what size sockets and such is needed.
Old Dec 14, 2006 | 01:17 PM
JAKE's Avatar
JAKE
The only reason I've read is that there was a BIG move to change the U.S. to the metric system years ago, but it failed. In the process there was to be a gradual transition from SAE and NPT to metric.
I still don't know why GM (and maybe others as well) continue with this mixture of different types.
Jake
Old Dec 14, 2006 | 04:20 PM
farscape1a's Avatar
farscape1a
Hey guys! I just got the bolts I ordered for the mount in the size M12x1.75x80 as Divette mentioned. They're way short. But, the diameter and thread pitch are correct. They have to be about 120mm in length. Just FYI for anyone else in my situation! Enjoy! Thanks for the help!
Old Dec 14, 2006 | 05:52 PM
1985 Corvette's Avatar
1985 Corvette
Is grade 8 the equivalent to 10.0?
Old Dec 14, 2006 | 06:34 PM
JAKE's Avatar
JAKE
According to the info I have, 10.9 Metric is the highest class used on our Vettes and Grade 8 the highest in the English. The strength of the bolt will be embossed on the head - in numbers for Metric (4.6, 8.8 etc) but little lines for the English system. Six hash lines indicates a Grade 8 bolt.
So I'd say that if you have a Metric bolt stamped 10.0, it's pretty close to Grade 8. Or to say it another way, a Grade 8 bolt is probably slightly stronger than a 10.0
Jake
To Engine mount bolts!!!
