First make sure it works manually. Then take out the assembly and plug it into the other side. If it still doesn't work, It's probably bad. The rebuilt unit cost isn't that bad. Used usually run $120-$150 exchange. My experience is in order of occurance, a.) bad pillets in motor, b.) bad controller (left front wheel well) usually one side goes out. C.) Bad motor.
If it's the motor itself I'd pursue the local electric shop alternative. If it's just brushes or something simple like that you're probably looking at $50-75 depending on labor where you live.
