91 Corvette Loose Steering Column
Old Dec 13, 2006 | 08:58 AM
platergd's Avatar
platergd
Default 91 Corvette Loose Steering Column
i Have 91 Vette And The Right Pivot Pin In The Column Keeps Backing Out Making The Column Loose After A Few Days. Has Anyone Delt With This Problem Or Know How To Fix It?
Old Dec 13, 2006 | 11:38 AM
dizwiz24's Avatar
dizwiz24
Its either the pivot pins coming loose (loose loc-tite) or -more likely the aluminum steering column housing bolt holes becoming elongated. A replacement of the the steering column housing is required. The parts may only be available as salvage.
I have the same problem.
Old Dec 13, 2006 | 12:21 PM
scranage's Avatar
scranage
Me too. I called for parts on my 92 the other day to find they are disconinued. After I get the thing apart if I find elongated holes, I'm thinking about reaming them out and putting steel inserts in with permatex sleeve retainer.
Old Dec 13, 2006 | 12:27 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
You can just change the housing, but you have to remove the column to do it. I have a friend here in Phoenix (with a shop), and he sells the part for $75.
Old Dec 13, 2006 | 02:45 PM
Vetracr's Avatar
Vetracr
Please post his name and number. There are more than a few of us who'd be interested. Thanks.
Larry
Old Dec 13, 2006 | 03:13 PM
zr1fred's Avatar
zr1fred
Max's Vette Stuff, 480-964-0779. He can rebuild them or sell you the parts you need. (and tell you how to do it)
To 91 Corvette Loose Steering Column
