Getting into my '91 tonight i shut the drivers door, but it stopped in the ajar position as i didnt shut it hard enough.
So i went to open it so i could shut it properly, but the door release handle did nothing! So i had to lower the window and open it using the outside handle.
Played about with both releases and locks etc.- no luck
Anyone else had this?
Before i start removing the door pannel is thair anything else i can check/do to remedy it ? Im guessing the release rod has broken inside, but only want to start tearing into the door pannel if i realy have to.
thats a good guess, just gonna have to tear the panel off and go from there, my actual door release handle came off, but had to remove the panel to fix anyway...
