ZF6 rear seal
Old Dec 14, 2006 | 04:07 PM
lefoy84's Avatar
lefoy84
Default ZF6 rear seal
Anyone know if you can change the rear seal without pulling the tranny?
Old Dec 14, 2006 | 05:32 PM
lefoy84's Avatar
lefoy84
Answered my own question. FSM says you can.
Old Dec 14, 2006 | 09:11 PM
bogus's Avatar
bogus
the seal itself is the same as the TH400.
Old Dec 14, 2006 | 09:18 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
And the parts stores listing for the ZF6 rear seal is wrong. So just get the TH400 seal.
Old Dec 14, 2006 | 10:03 PM
lefoy84's Avatar
lefoy84
Anyone have a good part # for the seal. Mine leaks just enough to foul the exhaust.
Old Apr 8, 2010 | 07:46 PM
MK 82's Avatar
MK 82
How about a part number for the TH400 seal please.
Old Apr 8, 2010 | 07:53 PM
LD85's Avatar
LD85
Been there done that, GMPARTSDIRECT.COM has the part #
Don't have to pull the tranny but when y pull the drive shaft all the liquid gold pours out
Old Apr 8, 2010 | 10:56 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Per Bill @ ZFDoc.com: NAPA P/N 18992
I will be buying one of these in the next couple of days.
Not sure if a flat-blade screwdriver is best to wedge it out -- or use a self-threading screw (or two), screw into rubber, and pull.
Also, wondering if I need to buy a short section of PVC pipe with similer/same diameter as seal to serve as a tool to knock it back in?
FYI: Doing this as PM since ZF is already out for motor swap.
To ZF6 rear seal
