Dana 44 Rear End
Old Dec 16, 2006 | 11:53 PM
WRIGHTCJW's Avatar
WRIGHTCJW
Default Dana 44 Rear End
HELLO, I HAVE A 95 VETTE. I'M CHANGING OUT THE REAR END GOING FROM DANA 36 TO 44. HAS ANY ONE MADE THIS CHANGE OVER BEFOR ? I DIDNT KNOW IF I HAD TO CHANGE OUT THE REAR LOW ARMS OR THE ARM FROM THE TRANY TO THE REAR? THANKS FOR THE HELP
Old Dec 17, 2006 | 12:04 AM
Quiktrp94's Avatar
Quiktrp94
You'll need a Dana 44 drive shaft and the support between the tranny and the diff. Robert
Old Dec 17, 2006 | 02:37 AM
bogus's Avatar
bogus
or, you can have the D36 shaft cut to fit and the c-beam redrilled.
Old Dec 17, 2006 | 02:41 AM
AZC4Guy's Avatar
AZC4Guy
There is a company here that will sel you a dana44 w/ all the needed goodies as a kit. They are called Exotic Muscle. A quick google search will show you the way.
FWIW I have one of their dana 44's on my car and have had no trouble w/ it.
Steve
Quik,... Robert is that you?
Old Dec 17, 2006 | 02:44 AM
Quiktrp94's Avatar
Quiktrp94
Steve
That's me.
Old Dec 17, 2006 | 03:10 AM
Casethecorvetteman's Avatar
Casethecorvetteman
Yeah to save stuffing around, get the driveshaft and c-beam from a 6 speed car. The c-beam from a DANA 36 is 15/16ths of an inch longer than the DANA 44 c-beam. You can drill new holes as Bogus says, but if you have the correct part to start with, its a straight out with the old, and straight in with the new. Much easier.
Old Dec 17, 2006 | 10:17 AM
Vic'89's Avatar
Vic'89
The easest way is to get the driveshaft and C-Beam from a 6 speed Vette. Then the entire install will be a direct bolton.
Vic
Old Dec 17, 2006 | 10:58 AM
grapeknutz's Avatar
grapeknutz
St. Jude Donor '06
Vic
The fun part about that is the trans yoke needs to be changed, and a new one is hard to find as chevy want to sell the whole driveshaft to you!
Old Dec 17, 2006 | 12:14 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
unless you have a friend who works at a dealership. That's how I got mine.
Old Dec 18, 2006 | 07:23 AM
Casethecorvetteman
You dont need a new trans yoke, you simply take the current one off the DANA 36 shaft and put it on the DANA 44 shaft. It couldnt be more simple.
To Dana 44 Rear End
