Aluminum block LT4???
Old Sep 27, 2001 | 04:56 PM
CBall's Avatar
CBall
Default Aluminum block LT4???
I don't think I'm crazy but....is it possible for a late 1996 LT4 to have an aluminum block??? Far from being an expert, I've had several look at it including my mechanic. Looks like, acts like, could it be aluminum????
Old Sep 27, 2001 | 05:02 PM
No Go's Avatar
No Go
Default Re: Aluminum block LT4??? (CBall)
It certainly wasn't offered from the factory and I've never heard of a LT1/4 aftermarket aluminum block. Cylinder heads yes-block no.
Old Sep 27, 2001 | 05:13 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Default Re: Aluminum block LT4??? (No Go)
GM offers a number of aluminum blocks over the counter. They are not cheap. Check Scoggin-Dickey's website http://www.sdpc2000.com/cart.asp?act...tart&catid=734
[Modified by Mez, 4:00 PM 9/27/2001]
Old Sep 27, 2001 | 05:38 PM
GlockLT4's Avatar
GlockLT4
LT4 didn't come from the factor with an aluminum block...
Old Sep 27, 2001 | 06:56 PM
silver & red CE's Avatar
silver & red CE
Like they said, aluminum heads, not block. I don't think there are any aluminum LT1/4/99 blocks anywhere. The lack of standard distributor mounting and the reverse flow cooling means that the standard aluminum blocks won't work. Maybe with some machining it can work, but I doubt it.
Eric
Old Sep 30, 2001 | 03:26 AM
FrankLT4CE's Avatar
FrankLT4CE
Default Re: Aluminum block LT4??? (silver & red CE)
Easy to find out for sure. Just use a magnet.
To Aluminum block LT4???
