4L60 pump to case gasket question
Old Dec 20, 2006 | 09:34 AM
danno85's Avatar
danno85
Default 4L60 pump to case gasket question
I just finished assembling a '93 model 4l60 and after I pulled the valve body gaskets from the kit I noticed another pump to case gasket slid in there after I'd already installed the pump. I didn't realize there were two gaskets in the kit and now I'm wondering if there are differences between them. The ATSG manual is pretty good about pointing out differences bwtween the various models and I don't see anything about the pump gasket. Anyone know? Pete?
Thanks!
Dan
Old Dec 20, 2006 | 09:40 AM
Pete K's Avatar
Pete K
Dan,
82 and 83 only used the gasket without the approx 1 inch bulge.
Use the gasket that has the "bulge" for your car.
Old Dec 20, 2006 | 09:43 AM
danno85's Avatar
danno85
Hmmm, not sure I know what you mean by "1 inch bulge". If I posted a pic of the gasket I have left over can you identify it?
Thanks for the quick reply!
Dan
Old Dec 20, 2006 | 09:51 AM
Pete K's Avatar
Pete K
Yes. If you post it, I can tell you for sure.
Old Dec 20, 2006 | 09:53 AM
danno85's Avatar
danno85
Old Dec 20, 2006 | 09:55 AM
Pete K's Avatar
Pete K
Originally Posted by danno85
Dan,
The pic you posted is of the INCORRECT gasket. If you feel like posting up the other gasket, I can show you the differences
Old Dec 20, 2006 | 10:00 AM
danno85's Avatar
danno85
So just to be clear, the pic I posted is the 82-83 gasket? The other is in the assembled transmission and I'm just trying to avoid pulling the pump back out, although that would be easier now that later!
Dan
Old Dec 20, 2006 | 10:01 AM
Pete K's Avatar
Pete K
Dan
Yes. The pic is 82-83 style. If the other gasket is installed, you are good to go.
Old Dec 20, 2006 | 10:05 AM
danno85's Avatar
danno85
Excellent - Thanks for your help, and I've appreciated the help you've provided others on the forum regarding the auto transmissions. I've learned a lot from those posts too.
Happy Holidays!
Dan
To 4L60 pump to case gasket question
