Accel 24lb injectors?
Old Sep 28, 2001 | 12:13 AM
KYVette90's Avatar
KYVette90
Default Accel 24lb injectors?
I saw a whole set of these 24lb injectors in Summit mag for only $239. Has anybody used them and are they any count? Also, with the mods listed in my signature, do you think I could upgrade to 24lb without any problems? Thanks. :flag
Old Sep 28, 2001 | 03:10 AM
88sk's Avatar
88sk
Default Re: Accel 24lb injectors? (89 Paul in cal)
the ford svo #24inj. are the same had to trim around inj. for clip(takes30seconds ea. inj.)also didnt go in as deep as stock, lots of people use them here& havent heard anything bad includ. mine, no leaks, I say try it, unless you want to spend more$$$..
Old Sep 28, 2001 | 03:42 AM
BowTie C4's Avatar
BowTie C4
Default Re: Accel 24lb injectors? (88sk)
nothing with a ford simble is aloud my car. Even if it's less expensive?????-----
I'll still know!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!! OUGH! :U
Old Sep 28, 2001 | 07:26 AM
cohocarl's Avatar
cohocarl
Default Re: Accel 24lb injectors? (KYVette90)
I replaced my stock injectors with Accel 24#'ers a couple months ago. The only problem I had was a little bit of excess yellow plastic under the upper O-ring on a couple. (if you get some, check under your o-rings before installation)
They fit fine on my 85, and work great. :yesnod:
Later,
Carl
Old Sep 28, 2001 | 09:32 AM
FoolCrzy's Avatar
FoolCrzy
I have Accel 24# injectors. They fit fine, and the c-clips worked fine. Plus they're yellow. that's kinda :cool: .
Old Sep 28, 2001 | 03:15 PM
SunCr's Avatar
SunCr
I went with Accel stock. They fit fine, only one stuck open after an initial run and even though I got a free replacement, it's a hassle to take everything apart, replace all the gaskets, o-rings, etc, a second time. Also, beware of little plastic splinters under the upper o-ring as mentioned earlier. I checked carefully before installation, but one didn't show up until the system was pressurized causing a leak at the rail. Overall, I think you get what you pay for and though quality is going to cost at least twice as much you will at least get peace of mind and unless you've got a monster motor, you don't need 24lb injectors.
Old Sep 28, 2001 | 03:33 PM
JR_VETTE's Avatar
JR_VETTE
Mid-TN Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Default Re: Accel 24lb injectors? (BowTie C4)
Psst....they're made by Bosch.
Old Sep 28, 2001 | 04:50 PM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
If you do decide to change them, do a pressure test on the system before you bolt the fuel rails back into the intake. I have read two posts from people who had one stick open. That can cause the cylinder to flood with fuel and damage the rod and piston because its try to compress a liquid. :eek:
Old Sep 28, 2001 | 06:13 PM
SunCr's Avatar
SunCr
Default Re: Accel 24lb injectors? (AquaMetallic94LT1)
Though I don't disagree that you might possibly damage a piston, the real danger with an open injector is that you might wash down the cylinder wall. Otherwise, the fuel is going to go out through the exhaust valve where it's greeted by the cat and raw fuel sitting in a 1000 degree cat is not a good thing! That's also why you always start the motor following an injector balance test.
Old Sep 28, 2001 | 06:42 PM
corvette1990's Avatar
corvette1990
Yes, the 24 pound Accel injectors work, you will probably be running richer though till you get an adjustable fuel regulator as well as have the car tested for Fuel vs O2. Then again the computer probably will learn from the O2 sensor and adjust the pulse of the larger injectors downward. I too cleaned the yellow plastic with an exacto knife and lubed the Orings before install. Buy some clips from GM, you will probably break one or two or eight.
Chris
Old Sep 28, 2001 | 08:32 PM
88sk's Avatar
88sk
thanks jreed, bowtie there are no ford symbols only #"s on injector body, I got them at http://www.mt. laurelmustang.com 6-months ago for $185. & they work great :eek:
To Accel 24lb injectors?
