Vacuum Leaks
Old Dec 23, 2006 | 12:02 PM
dens cvette's Avatar
dens cvette
5th Gear
Default Vacuum Leaks
I have a 94 and need to check for vacuum leaks. Any good sugestions where to start or where leaks commonly occur?
Old Dec 23, 2006 | 04:17 PM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
Anywhere and everywhere
Get a vacuum tester Its a little pump
They also have the things that blow smoke into the system and just look for it to come out
This is really a pity post I just hate to see 0 responses
PS one reason no responses is because no one knows what it is
a 94 what?????
Old Dec 23, 2006 | 04:44 PM
RRT vette's Avatar
RRT vette
a 94 what?????
It's a 94 Ford Taurus.
A vac guage and pump as suggested will be a great tool.
Also spraying starting fluid or using unlit propane on the lines while the engine is at idle. If either is introduced into the lines the idle will increase some.
Old Dec 24, 2006 | 10:04 AM
mikey whipreck's Avatar
mikey whipreck
A mechanic's stethoscope helped me with my '85. I found a big vac leak at the cold start injector with that. I got it from harbor freight for about 5 bucks.
To Vacuum Leaks
