side by side header comparison
Old Dec 23, 2006 | 02:39 PM
GS977's Avatar
GS977
Default side by side header comparison
my TPIS headers that i just took off and the new EM headers
Old Dec 23, 2006 | 02:41 PM
GS977's Avatar
GS977
Old Dec 23, 2006 | 02:44 PM
5abivt's Avatar
5abivt
Very nice . The EM longtubes appear to have a 'd' shape port on the pipes. Are the LT4 heads 'D' shaped on the exhaust? ALso the angles look different on the collector looks like you'll have a little fun mating it up to your current exhaust. Im real curious to know how they fit in there. please keep us posted !!
Old Dec 23, 2006 | 02:49 PM
5abivt's Avatar
5abivt
One thing i would like to add is about all the talk of 1 7/8s being too big. I notice on the LG (c5/6) headers they claim the most power. At the ends of their primaries they neck down a bit (the primaries merge into a 2 1/2 or 2 3/4 collector then it flares to a 3") to maintain velocity to help scavenging and low speed torque. No c4 header has ever had that setup like theirs. I wish they would make longtubes for us.
From looking at your headers Im picturing the exhaust flow in a 1 7/8th pipe will be a bit slower. Wether or not it will add power will depends on how much of a restriction if any the 1 3/4s were causing. Then the flow would dump into a 3" collector where it would slow even further.
My guess is you will lose low end torque but pick up in the high-mid and high end range of your powerband. Please get it dyno'd without any other changes and post your results !! This is great info and would put to rest alot of BS rumors about header size etc.
Last but not least it looks that the primaries are different lengths on the Ems. This might possibly mean they were measured and produced with the optimal lengths to provide the best scavenging effect possible. ??
Old Dec 23, 2006 | 04:31 PM
Zix's Avatar
Zix
The LG C5 and C6 headers (except for their budget version) use merge collectors, which is the neck-down that you see. If you look at the 1-7/8 EM headers you'll also see merge collectors, this is to keep the exhaust gasses flowing as fast as possible to help woth scavenging. These headers are best matched to high-revving motors. They also have a version that are 1 3/4" stepped to 1 7/8" which also helps with low RPM flow.
Old Dec 23, 2006 | 08:14 PM
AKS Racing's Avatar
AKS Racing
You are making me so want to buy the EM headers. My TPIS LTs look nearly identical to yours even with the requisite "hole" in the outside of the #2 cylinder and the chafe marks on the inside of the same tube.
The EM look so much better than the old TPIS. I will await final word on install.
As an aside, did they offer 1 7/8" stepped to 2" as an option for the C4 chassis?
Aaron
Old Dec 23, 2006 | 10:59 PM
Raidmagic's Avatar
Raidmagic
What is that from? Do they rub on something? I have the Melrose system on my car and they don't hit anywhere. I just hope the coating holds up over time so they stay looking nice.
Old Dec 24, 2006 | 12:04 AM
Red Tornado's Avatar
Red Tornado
the EM headers seem to have some extra bends in the pipes.
my shriveled little mind thinks that's not quite so great.
Old Dec 24, 2006 | 12:27 AM
5abivt's Avatar
5abivt
That is always true. But if they are the right length to have perfect timing so the scavenging effect will be maximized... the few extra bends are worth it.
Old Dec 24, 2006 | 11:20 AM
AKS Racing's Avatar
AKS Racing
The hole on the outside of #2 is from one of the bolts on the corner brace that attaches to the framerail. I had ground the head of the bolt down considerably, but when the motor tourqed over, it would still hit. Eventually, I had to do a small repair.
Do not get me wrong, I like my TPIS LTs, it is just that I would like to step up to a larger, nicer header if I were to go to the expense of another header install on my '87.
Aaron
Old Dec 24, 2006 | 12:30 PM
resipsa's Avatar
resipsa
Your EM LTs look much different than the ones I purchased last year. Mine were for an LT1 and have 1 3/4 primaries.
Old Dec 24, 2006 | 12:34 PM
Bad Karma's Avatar
Bad Karma
Exactly.
And it would be nice if there was a header with a merge collector for us.
Old Dec 24, 2006 | 12:50 PM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
Paul, this are the 1 7/8 headers, where I'm sure you're using the 1 3/4s just like me. The big ones cost more than twice as much and you really need an engine that spins high rpms.
Old Dec 24, 2006 | 01:17 PM
Zix's Avatar
Zix
Originally Posted by Michael_ERT
Exactly.
The EM's in this thread have merge collectors.
The extra bends are to help make the pipes equal length, they actually help more than hurt the exhaust flow
Old Dec 24, 2006 | 01:41 PM
resipsa's Avatar
resipsa
I have the 1 3/4 EM LTs. I was just commenting about how different they looked from the 1 7/8 model.
Seems like a lot of money and effort for a single digit rear-wheel horsepower gain. I assume that GS977 has other plans for the motor in that car (a great looking car BTW) which will benefit from that upgrade, e.g., 300+cfm intake ports, bigger cam, etc.
Old Dec 24, 2006 | 03:26 PM
GS977's Avatar
GS977
hey guys, i thought you might wanna see the TPIS collector. i posted a pic of the EM merge collector already, now look at this.
and also the diff in pipe size.
Old Dec 24, 2006 | 03:27 PM
GS977's Avatar
GS977
To side by side header comparison
Old Dec 24, 2006 | 09:51 PM
resipsa's Avatar
resipsa
Quite a difference in quality!!!
Old Dec 26, 2006 | 02:01 AM
MarkBychowski's Avatar
MarkBychowski
Just to clarify for the guys thinking about the EM 1-3/4" headers. They don't have the merge collector like GS977's. His headers are a significant step up from their standard model. I have EM 1-3/4 headers and they're very nice, but the collector is a standard 4-to-1 collector like the TPIS one shone above.
GS977, those are definitely sweet headers! If it wouldn't cost me a marraige, I'd upgrade
Old Dec 26, 2006 | 03:25 AM
TIMSPEED's Avatar
TIMSPEED
FWIW, A couple of guys running big cubic inch small block's in C4's, actually still ran 1 5/8" headers and didn't lose any power verses running a 1 3/4" header....just food for thought... (and both cars ran deep in the 10's)
