Grease points on a '92
Old Dec 24, 2006 | 12:01 AM
MrWiggly's Avatar
MrWiggly
From: Sunny Seaside Seabrook Texas (a whole 'nother country)
Default Grease points on a '92
How many places are there to grease on a '92 chassis lube job? I don't think my local shop is getting them all!
Thanks all-knowing list...
Old Dec 24, 2006 | 12:10 AM
bogus's Avatar
bogus
IIRC, the only points are the ball joints and tie rods. There are rear tie rods, but I don't remember if they are greasable.
The ujoints, at least factory units, are not.
Old Dec 24, 2006 | 11:45 AM
c4cruiser's Avatar
c4cruiser
The upper and lower ball joints, and the two outside tie rod ends are the only zerk fittings you will find. GM went to a sealed rear tie rod end around 89 or 90.
There are aftermarket rear tie rod ends that may have fittings so if they have been replaced at some point, you should look.
Most of the replacement u-joints for the driveshaft and half-shaft are the sealed type, but there are greaseabe u-joints out there so a check is in order there too.
To Grease points on a '92
