Engine Cut Out While Driving On Highway - Need Advice!
Old Sep 28, 2001 | 05:24 PM
ChrisW89's Avatar
ChrisW89
1st Gear
Default Engine Cut Out While Driving On Highway - Need Advice!
My first problem, hence my first post!
While driving on the hwy - about 130kph, my speed started to drop and I realized that my engine had died. I pulled over to the shoulder and called for a tow. From time to time, while waiting for the truck, I tried to start the engine. It would crank but wouldnt start. When I got the car back home and unloaded it from the truck, it started with no problem! I have tested the pressure at the fuel rail and it seems fine (35-40 lbs). At first I suspected the fuel pump, but now I'm not so sure. I don't mind changing the fuel pump if this is what is wrong. Another hint may be that before this happened, I had noticed that the idle seemed a little higher than normal. By the way, the car is an 89 with about 160k km.
Any ideas?
Old Sep 28, 2001 | 05:35 PM
MrJay's Avatar
MrJay
Default Re: Engine Cut Out While Driving On Highway - Need Advice! (ChrisW89)
I would think it is something in the timeing because it got better when the engine got cold again, it sound like maybe a coil is getting hot and quiting on you or something like that.
Wish I could help you more but hope this helps a little.
Jay
Old Sep 28, 2001 | 05:44 PM
CAJUN C4's Avatar
CAJUN C4
I had the Exact same problem...It's either the Ignition Module, My first guess or the Pick-up module. Could be coil Because it does it when Hot. I went through 5 Ignition modules in 3 months because my Pick up Module was the coulprit and would burn them out.Changed them both,no trouble for 2 years now.I did however change the coil as well .
Old Sep 28, 2001 | 06:23 PM
into01000101's Avatar
into01000101
Default Re: Engine Cut Out While Driving On Highway - Need Advice! (CAJUN C4)
Keep an eye on the computer. My car was having literally the exact same problem. I would drive down the road, everything was doing fine and then BAM, it would sputter and die. Then it would start back up a few minutes later and start the whole thing over again. I took it into the dealer, and even though my computer wasn't showing any codes, it was messed up. They simply replaced my computer and it has been perfect since. I didn't even suspect my computer! I don't like going to dealers for work, but they diagnosed it right the first time and fixed it fast. You could spend hundreds on fixing it yourself, and still not find the problem. It may pay to do a diagnosis at a shop, since your car dying on a road is very dangerous. period.
Old Sep 28, 2001 | 06:25 PM
into01000101
Default Re: Engine Cut Out While Driving On Highway - Need Advice! (into01000101)
Keep in mind that Cajun C4 has an 84, and his diagnosis was for the Cross Fire Injected variant, not the Tuned Port setup(assuming). Different setups have different problems. Good Luck!
Old Sep 28, 2001 | 06:30 PM
Justin Scherer's Avatar
Justin Scherer
Well, if its a '92 through '96 it fits PERFECTLY the description of an Opti Spark problem. Mine did the exact same thing to me. Then 7 months later it left me stranded (just cutting out at highway speed). I had done the whole fuel rail pressure thing and all. Only other symptom I had at the time was difficulty starting on wet mornings.
Justin....
[Modified by Justin Scherer, 4:31 PM 9/28/2001]
Old Sep 28, 2001 | 06:38 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Default Re: Engine Cut Out While Driving On Highway - Need Advice! (Justin Scherer)
It does sound like the igntion module or coil can be on its way out...it can also be a number of things and unless youre able to test the parts yourself, its going to be a trial and error of throwing parts at the car and taking a chance.
It can be the ecm, who knows.
WHen my 86 had this problem, it was the MAF sensor..if your car dies and you pull over, open the hood and unplug the MAF sensor and see if it will start up any better then nothing at all...it will run rough unplugged but it can help pinpoint.
Try and see if theres any trouble codes stored in the ecm.If the MAF is the probem, change the relays the same time.
Hope you dont get stuck throwing parts at the car and not solving it the first time out.
Let us know what you find and also the condition of the ignition module,coil and etc.
Old Sep 28, 2001 | 09:33 PM
DoubleAught's Avatar
DoubleAught
Mine did the same thing...it turned out to be an electrical failure that took out both the ignition module & the computer. It would start, run long enough to get out of the drive & down the block, and then die. It doesn't take very long for the injectors to foul the plugs when there's no spark, either.
Old Sep 28, 2001 | 11:59 PM
R23HTC's Avatar
R23HTC
Default Re: Engine Cut Out While Driving On Highway - Need Advice! (DoubleAught)
I had a similar problem and it was the coil and wires. I'd defiantely check your coil.
Old Oct 2, 2001 | 02:54 AM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
Default Re: Engine Cut Out While Driving On Highway - Need Advice! (R94 LT 1)
I had the same problem on my 90. Fuel pressure was okay and there were no codes.
I replaced the ignition module and that fixed it.
To Engine Cut Out While Driving On Highway - Need Advice!
