Cam help...
Old Dec 25, 2006 | 02:01 PM
Pony_Fed95's Avatar
Pony_Fed95
Default Cam help...
I need a cam for my 96 LT4 6SPD. Current mods are bolts on's and a 125 shot. Its time for a cam. I need help on knowing which one to get. Should I get a cam kit? Or piece one together myself?
Old Dec 25, 2006 | 02:28 PM
STL94LT1's Avatar
STL94LT1
I like Comp Cams XFI series, which grind depends on future mods. Also, with your LT4 you really don't need a cam kit, just buy a camshaft and stick it in. If the car isn't too high mileage, you can even reuse the lifters.
Old Dec 26, 2006 | 03:37 PM
Pony_Fed95's Avatar
Pony_Fed95
I am wanting to make around 370 on the motor. Future mods will be Hydro lifters, 58mm TB, probably port the intake mani and maybe the heads. Car has 100k on it.
Old Dec 26, 2006 | 05:35 PM
STL94LT1's Avatar
STL94LT1
With 100k on the engine. I would install new lifters, valve springs, and timing set with the camshaft.
Old Dec 26, 2006 | 06:24 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
THAT is the right way to do it.
Using old lifters may not be such a good idea.
It's my habit to use new lifters with a new cam.
The valve spring pressure on our engines is pretty mild so you could probably get away with using the old ones but why take a chance on it? New set of lifters doesn't cost that much.
Old Dec 27, 2006 | 12:33 AM
Pony_Fed95's Avatar
Pony_Fed95
Yea I had planned on all of that. I wouldnt feel right without replacing all of the components.
Old Dec 27, 2006 | 12:45 AM
cv67's Avatar
cv67
St. Jude Donor '05
even if the had 30k on them, they are still almost 11 years old. Better safe than sorry to replace them.
Old Dec 27, 2006 | 11:02 AM
sami85L98's Avatar
sami85L98
Follow nathan plemon's dyno graph :
http://www.wku.edu/~nathan.plemons/h..._corvette.html
Old Dec 28, 2006 | 01:29 PM
Pony_Fed95's Avatar
Pony_Fed95
thanks.
To Cam help...
