Optispark tip....
Old Dec 27, 2006 | 02:19 PM
jimkmyc5's Avatar
jimkmyc5
Default Optispark tip....
When installing the optispark....be extra careful with the drive gear. It most definately goes in two ways, without resistance, about 15 degrees apart on my car.
I just reassembled mine for the second time after correcting this. I put it back together the first time and got a no start with backfiring through the intake, I was like...WTF!??!!
I took it apart again and discovered the problem and corrected.
Its funny that my first install took about seven hours and my second try I did it in about 2 1/2 hours Its amazing how fast we learn!
Old Dec 27, 2006 | 02:28 PM
Carpenter's Avatar
Carpenter
What year?
Old Dec 27, 2006 | 04:11 PM
SJW's Avatar
SJW
This is why I recommend a brief test-firing of the engine before the water pump goes back on. If there's a major problem with the Opti, you'll find out while it's still accessible. Glad you got yours straightened out. Bummer about the re-do.
Be well,
SJW
Old Dec 28, 2006 | 03:57 PM
jimkmyc5's Avatar
jimkmyc5
Be well,
SJW
I took your tip on the second go round, fired right up!
Oh, its a 92 I've been fiddling with. Its a 125k coupe, auto, black rose all stock, everything works. I was changing the radiator, decided to go ahead and do the waterpump and hoses...while I'm at it, opti,plugs and wires. I suppose everyone knows how beat up my hands ae right now! Later. Jim
To Optispark tip....
