1984 - no oil pressure/pump?
Old Dec 27, 2006 | 02:22 PM
brittlh's Avatar
brittlh
5th Gear
Default 1984 - no oil pressure/pump?
I'm new to the forum, because a couple of months again I trashed my '84 Corvette. I was going down the highway at about 65mph and the oil pressure dropped to zero. It just kind of bogged out, no lound noises or anything. It would not restart and I just had it towed to my home thinking the worst. I have checked the oil and it was a little low and seems to get that way after a little driving since I bought it a year ago. I added oil to the full level and tried starting it with no results. The oil pressure never goes up. Is this just an oil pump or have I blown the rest of it up. It is the stock engine with 103,000 miles. I was not racing it or revving it when it happened. Thanks for all your ideas. I have a friend I trust to change the oil pump if that's needed, but not sure how good of a troubleshooter he is. Thanks,
Britt
Old Dec 27, 2006 | 02:37 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Does it turn over freely or is the engine locked up?
Old Dec 27, 2006 | 02:43 PM
brittlh's Avatar
brittlh
5th Gear
Default turns over freely?
Yes, it turns over freely, but doesn't make much effor to start. Oil pressure never goes up at all. Checked the look of the oil and I don't see any water in it or anything.
Old Dec 27, 2006 | 03:04 PM
Black84's Avatar
Black84
Not a lot of information to go on but my first guess is a broken distributor...
zr1fred's Avatar
zr1fred
It doesn't SOUND like you lost the oil pump. More likely a fuel pump/ ignition problem. The fuel pump wiring goes through the oil pressure sending unit. If you're oil pump went out at 65mph you should have locked up the engine.
Old Dec 27, 2006 | 04:43 PM
brittlh's Avatar
brittlh
5th Gear
The last thing I fixed on it was the belt tensioner. It had locked up solid. Would this have any effect on other systems? I relplaced it after only a block or so of driving while the tensioner was squeeling. Then I drove it 2 or 3 times more when I had this "oil pump" problem. Am I going to get an error code or something to lead me more to the fuel pump or distributor? Thanks.
Old Dec 27, 2006 | 05:23 PM
IRAraid's Avatar
IRAraid
Default Zero oil pressure
The oil pressure likely went to zero because the engine quit.
Check out the 'simple' stuff before sweating a heavy duty job like the oil pump.
Getting fuel?
Getting spark?
Or??? was the engine pulling hard when the oil pressure dropped = Oh crap!
Good luck.
Old Dec 27, 2006 | 06:37 PM
brittlh's Avatar
brittlh
5th Gear
Default not the oil pump
I just forced it to start. It started and I drove it to the gas station to get gas. I now have too much oil in it, which isn't a big deal. I guess I should look at the fuel pump and distributor. I replaced the spark plugs and cap recently. Thanks for all the good ideas so far.
To 1984 - no oil pressure/pump?
