Hello:
I am using C4 parts for my 55 Chevy truck http://www.cardomain.com/ride/2330005
Which is the inlet port on the steering rack? Smaller or larger one?
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
The inlet port hooks up to the crimped pressure line from the pump. The return from the rack is through a NPT threaded nipple with a 3/8" hose clamped to it. I think the inlet is larger, but they shouldn't even be interchangeable.
Checked my Factory Shop Manual - it shows the port closest to the left wheel to be the pressure port. According to my NAPA book, the return line is 16MM threads. The pressure line has a 16MM and a 18MM end, the book doesn't say which is to the rack. GM usually has the pressure port larger. I would look at my vette to make sure - but there is 2 to 4 feet of snow on the ground and against the garage door!
