Help getting off harmonic balancer
Old Dec 28, 2006 | 05:13 PM
Bozzy90210's Avatar
Bozzy90210
Default Help getting off harmonic balancer
Im in the process of changing my opti out and need to get the balancer off. Ive got a balance puller install but am havinbg to put a lot of force on it. Im nearly bending an 18" breaker bar. Is this normal?
I put the 3 bolts in deep enoough to get some clearence, is that ok Im assuming the hub behind it come off with the balancer. I tried wacking it a few times from behind with a 2x2 but to no avail. Yes i have the center bolt out.
Thoughts?
Thanks!
Old Dec 28, 2006 | 05:27 PM
96GS#007's Avatar
96GS#007
To just change the Opti, the hub stays in place. Remove the 3 bolts that secure the balancer to the hub and then remove the balancer. With age, the balancer siezes on the hub so it will likely need a little force to get it off. If you continue trying to pry the entire assembly off, you're going to screw up the hub/balancer at a minimum and risk screwing up the crankshaft snout as well.
Btw...although the hub stays in place, you may have to rotate it (ie rotate the engine) so that the Opti will clear the "fingers".
Btw #2...Before you ask, the balancer will only go back on one way.
The Factory Service Manual clearly outlines this entire procedure. You can generally find a like new set on e-Bay for less than $75. Your Corvette will thank you.
Old Dec 28, 2006 | 06:04 PM
Bozzy90210's Avatar
Bozzy90210
Default getting there now how to remove it
Thanks for that response. I felt the front of the crank and it seems undamaged. On page 6a1a11 in the manual it state to pull the hub off. Im glad its nt necessary. any hints for removing the balancer or is hitting with wood from the back the way?
Old Dec 28, 2006 | 06:47 PM
Bozzy90210's Avatar
Bozzy90210
Default All done
used the wood from the back trick.
Thanks again
To Help getting off harmonic balancer
