calibrator...
Old Dec 28, 2006 | 11:42 PM
86malcomekonnner's Avatar
86malcomekonnner
Default calibrator...
I've decided to put the 3.54's in this week but i need to calibrate the speedo...i remember seeing a calibration box in the forum store but i cant find it now....is there a speedo gear available for 3.54's because i cant find one? Thanks Jay
Old Dec 28, 2006 | 11:55 PM
Hooked on Vettes's Avatar
Hooked on Vettes
http://www.dakotadigital.com
SGI-5 seems to be the best buy. The manufacturer for some reason sells it cheaper than even Summit Racing.
Old Dec 29, 2006 | 02:42 PM
C4Techie's Avatar
C4Techie
With P255/50ZR16 Tires. Ratio: 3.54. Drive gear: 8642620, Grey, 15T. Driven gear: 25513049, Green, 42T. VSS: 25007308.
Old Dec 29, 2006 | 03:48 PM
James93LT1's Avatar
James93LT1
Veteran: National Guard
http://www.corvetteforum.net/c4/vett...Gearshtm.shtml
Old Dec 29, 2006 | 06:33 PM
86malcomekonnner
ok now do i need the drive gear, driven gear, and speed sensor? Where are they located? And are those GM p/n's?
Old Dec 29, 2006 | 06:49 PM
C4Techie's Avatar
C4Techie
Yes. You will need one of each of all three. If different, you may be able to turn the VSS up side down to make it work, instead of trying to buy an obsolete part. You won't have to buy the parts that are the same as you already have. In the tailshaft housing. Yes, GM.
Old Dec 29, 2006 | 10:52 PM
Lichen's Avatar
Lichen
I got mine from Exotic Muscle.
Old Dec 29, 2006 | 11:01 PM
Pete K's Avatar
Pete K
I have the gm gears here. The grey drive gear and 43 tooth blue driven gear are both still available. If you have trouble getting them, shoot me a pm.
To calibrator...
