I have my scanner hooked up running Craig's software. I noticed today that my car is not going into open loop at WOT. Also the TCC never requests lockup. :cry What would cause this? The car seems strong, but this is not right. Please help. I have been searching the site, but I absolutely hate the new search screen. Love everything else. :p: Thanks a million!
Is the scanner code set up properly for your car's motor?
What is the TPS reading at WOT?
What is the BM cell number at WOT?
What is the BM cell value at WOT?
Connect a test lamp or a 2.2k Ohm 1/4 Watt resistor in series with a mini-LED across ALDL pins F & A to check for the lockup command (LED goes Off when the ECM issues the lockup command to the tranny).
Yes I get all other readings no problem....
Throttle position at WOT is 83.375% at idle its ~10.xx%
Not real sure were to find this....the course and fine on craig's software are both 128
Will have to try this......
Thanks for the reply. Can you help me out now with the info I provided? This is really a bummer. I am looking forward to hearing from all you. You are all really helpful here. Thanks.
