manifold/heads match
Old Dec 29, 2006 | 10:17 AM
conv90's Avatar
conv90
Default manifold/heads match
Is there a a good way to measure with good accuracy the angle of the surface of the heads (the surface where there are the intake ports...) and the same angle on the surfaces of the intake manifold?
Just trying to figure if a difference exists and avoid to have a difference.
If a difference is registerd, a milling on the surface of the intake manifold can solve the problem... expeciallly if the gap is at the bottom (lifter valley exposed).
I'm open to suggestions to read these angles with good accuracy ...
-Beppe-
