brake problems..
Old Sep 29, 2001 | 12:16 PM
jackyy's Avatar
jackyy
Default brake problems..
hey guys like i said 3 weeks ago i got my brake pads and rotors changes but now it seems like my brakes squeke and grind at times..mostly when im going slow and brake slowly;what can the problem be?..did they put on brakes that were not good?
thanx
[Modified by jackyy, 10:16 AM 9/29/2001]
Old Sep 29, 2001 | 06:00 PM
92TripleBlack's Avatar
92TripleBlack
Default Re: brake problems.. (jackyy)
Brakes need to have a "break-in" period when you use them lightly and let the parts wear a little until they mate perfectly. During this time, any heavy braking can damage the parts. The brakes will also squeek and grind a little more as the parts wear. You would hear this at slower lighter braking as you are not squeezing hard to make the brake's mate properly from pressure. I have been told about 500 miles of average driving without heavy stops should give the brakes enough use to properly wear. If you don't have the mies on yet and haven't made any heavy stops I wouldn't worry about it. Anyone have any different times on this? I unfortunately am not an expert on this an I'm just passing on what I have heard from brake people.
92TripleBlack :cheers:
Old Sep 29, 2001 | 06:17 PM
jackyy's Avatar
jackyy
Default Re: brake problems.. (92TripleBlack)
thanx ;should go back to the shop just to be sure so they don't stiff me with the bill if something is really wrong?
thanx
Old Sep 29, 2001 | 07:11 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Did you follow the breakin procedure per the service manual???????
Old Sep 29, 2001 | 07:14 PM
92TripleBlack
Default Re: brake problems.. (mackeyred96)
I'd read the manual and call the shop just to be sure. They should gibve you good feedback if its a good place.
92TripleBlack
To brake problems..
