heyy
Old Dec 30, 2006 | 02:15 AM
MexCareBear's Avatar
MexCareBear
Default heyy
hey...well my warrenty for my car has gone out now...so i can finally take my cats out...i dont really have the money rite now so im going to leave them in but break whatever is inside of the cats out...now...if i did that would my car throw codes out or would it act different...would it mess up...would it still drive the same???...please help?
Old Dec 30, 2006 | 02:26 AM
RRT vette's Avatar
RRT vette
The rear/post cat O2 sensors might throw a code. I believe it is better to install hiflow cats in the original cats place. With the original cats "hollow" it will cause a turbulance in flow. There will be little HP gain either way. JMO
I know there will be a richer/more unpleasant smell to the exhaust with the cats "hollow" or removed. Perhaps someone that has done this with there 96 can help, to be certain.
Old Dec 30, 2006 | 02:29 AM
MexCareBear
ok so what happends if i jus buy long tube headers wit a full exhuast with no cats...what happends with the o2 sensors?...would i have to upgrade them or put it on the after market exhuast?
Old Dec 30, 2006 | 02:35 AM
RRT vette's Avatar
RRT vette
I believe you would need a tune to correct for the deleted post cat O2 sensors, so no codes would be thrown..
Old Dec 30, 2006 | 02:45 AM
MexCareBear
hmmm so basically i would get codes if i hollow it out?...i should research lol...thanks for the help seriously
Old Dec 30, 2006 | 04:44 AM
LouisvilleLT4's Avatar
LouisvilleLT4
basically....I....am....in....the....mid dle....of....the....same....project...ri ght....now....of...delelting...my....cat s....
my...plan...is....to....delete....the... .second....set....of....O2....sensors... .by....sending....my....PCM....off....to ....PCMforless....but...there's....no... .rush....because....my....car....is....a lready....throwing....the....same....... ..code.....that....it........would....if .....the.....cats....were.....gone....(t hey're....clogged....up....as.....it.... .is).
i'm.....going.....on......an......all... .out................weight.............r eduction.............route.........so... ...your.....best...........choice....... of........whether.......to.............k eep................cats.........or...... ...not.........might.......differ....... .from.........mine.........
to......eliminate..........the.......... .cat's.........I'm............buying.... ....a........set........of.......Hooker. .....2151.........longtube.......exhaust .........headers...........and........dr illing........O2.........sensor......... bungs.......on......each..........collec tor.........for........the.......first.. ......set........of.....O2..........sens ors..................................... ........................
by the way has anyone seen my shift key, and my period key seems to be stukc
Old Dec 30, 2006 | 05:02 AM
jsavoy's Avatar
jsavoy
easy on the ellipses.
BTW, Warranty just expired? What type of extended warranty did you have?
Old Dec 30, 2006 | 08:42 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
If the car you're working on is a 96 (you need to specify), you have an OBD2 system (the only C-4 that does) THere is an o2 sensor behind the cats that will throw codes AND change the way it runs (and not for the better). On road, I can think of no reason to ever gut the cats. they are very large HIGH flow units, that have almost no restriction. Except for a little more noise, you'll never notice any difference. The days of the high restriction cats ended in the 80's
Old Dec 30, 2006 | 09:16 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
If it ain't broke don't F_ _ _ with it!
Old Dec 30, 2006 | 10:48 AM
Carpenter's Avatar
Carpenter
I'd leave it alone, at least until you decide to install long tubes.
Old Dec 30, 2006 | 11:04 AM
MikeC4's Avatar
MikeC4
...and in addition, we all got do our 'little' part in pollution redux....
Old Dec 30, 2006 | 11:36 AM
jimg's'93's Avatar
jimg's'93
Have you considered hi-flow cats instead of removal? The HP degradation is minimal and you won't have to mess with the whole sensor situation. This is what I'm considering when mine decide to go (It ain't broke....yet).
Has anyone else tried these?
Old Dec 30, 2006 | 12:28 PM
LouisvilleLT4
I agree; don't get me wrong, removing the cats is not worth much in terms of horsepower and you're better off getting bullet cats so you can save the hassle, be able to pass emissions should you ever need to, and still get the exact same performance gains. Unless you're like me and really trying to get the car as light as humanly possible, then you shouldn't simply rip them out.
Old Dec 30, 2006 | 12:53 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
If it ain't broke don't fix it.
Unless you have a master plan, leave them alone until you are ready to execute the entire plan.
Old Dec 30, 2006 | 12:54 PM
Mr Mojo's Avatar
Mr Mojo
or better yet, how many miles? You could always donate them to me, so I can replace my high mileage stockers when they finally go.
To heyy
