Electric Water Pump
Old Dec 30, 2006 | 02:56 AM
BrassRing's Avatar
BrassRing
Default Electric Water Pump
I'm replacing my water pump, timing chain and sprockets. I was think about going to an electric water pump while I was in there, but I don't know much about them. Does anyone have any experience installing an electric water pump? Is it worth it? Which ones do you recommend? What should I look out for?
Old Dec 30, 2006 | 05:21 AM
jsavoy's Avatar
jsavoy
There are a LOT of opinions on this topic already posted and commenting on this would be
A quick C4 forum search of electric water pumps yields:
http://forums.corvetteforum.com/show....php?t=1555157
http://forums.corvetteforum.com/show....php?t=1570995
http://forums.corvetteforum.com/show....php?t=1573020
Installation:
http://www.projecttransam.com/projects9.asp
Old Dec 30, 2006 | 11:39 AM
JA94vette's Avatar
JA94vette
I put one on my vette a few months ago. I really like it and it works great. Easy to install. But you need a press to get the old shaft out of the water pump housing. Good luck!!
Old Dec 30, 2006 | 06:26 PM
Strick's Avatar
Strick
https://www.corvetteforum.com/techti...=231&TopicID=2
All you need to know
Old Dec 30, 2006 | 06:48 PM
Hotred94's Avatar
Hotred94
Meziere pump is the pump of choice amonst C4 owners. Mine has been in for a year with no problems, plus it allows me to circulate the coolant when the engine is off and during coolant changes. Press is not needed, just a careful whack with a hammer to knock the shaft out of the housing. Good luck.
Old Dec 31, 2006 | 02:52 PM
BrassRing's Avatar
BrassRing
Thanks guys for your help! I needed a good introduction to understand the benefits of the electric water pump. Sounds like the Meziere 300HD series is the way to go. However, I think I am going to hold off right now. I have the L98 so I don't have the added benefits of 1 less oil seal and the opti-spark risk under the water pump, which you all have for the LT motors. I like the additional cooling power at all RPMs, but I'm not sure I NEED this $360 feature right now. There are other more urgent mods on my list. So this one will wait a bit. Thanks again.
To Electric Water Pump
