'89 Climate Control Light Bulb
Old Dec 30, 2006 | 12:22 PM
Clay Assassin's Avatar
Clay Assassin
Default '89 Climate Control Light Bulb
Where do I get one of these, and what the heck is it?
I have the auto climate control on my 89.
I am guessing a light bulb is burned out, since its dark in one spot with the lights on, and works fine.
Anybody know what type it is and where I could get one?
Thanks in advance.
Old Dec 30, 2006 | 08:34 PM
TiIngot's Avatar
TiIngot
This may be a tough one. If your's is the same as my '96 I can tell you how to get the control head out of the dash, disassemble it and remove the bulbs. However my service manual does not have a list of the replacement bulb that I can find. This link is a summary of how I removed and disassembled my control head from the dash
http://forums.corvetteforum,com/show....php?t=1519199
Old Dec 30, 2006 | 08:52 PM
TiIngot's Avatar
TiIngot
Does your owners manual list a replacement bulb???
Old Dec 30, 2006 | 11:04 PM
tonymax2's Avatar
tonymax2
According to my '89 FSM, the Air Conditioner/Heater Controls lamp is a trade #37. I'd check at a local auto parts store first. Hopefully it's a standard, low intensity bulb.
Old Dec 31, 2006 | 12:27 PM
Clay Assassin
Thanks Tonymax.
#37!
Had to go to three stores to get it. One fixed!
Got a bulb out on my 98 blazer too. Bulbs are soldered into the board on that one. I bet they are soldered in on the 96 vette too.
May not be so easy....
Old Dec 31, 2006 | 05:25 PM
TiIngot's Avatar
TiIngot
The climate control bulbs are not soldered in on a '96. They are inside the climate control box. After removing the control box and opening it up you need a small screw driver to turn the bulb a quarter turn to remove it from the circuit board it is mounted on.
To '89 Climate Control Light Bulb
