Rich issue!
I don't know the history but I did find receipts for lots of electrical problem diagnostics and notes on those receipts about the fact that at some time in the past someone was in the dash fiddling with things. I have since had the entire dash out of the car and have put things into more of a factory order, but I could tell that this thing had been tampered with in a big way at some point. I only wish I knew the detailed history.
Carfax report showed most of its miles put on in it's first 5 years and then it seemed to have sat for a long time.
I haven't really had any issues with it for the five years I've had it so I can't complain. It's 20 years old and things like this are bound to happen, the odometer reads 178,000.
It's never left me on the side of the road.
I pulled all the plugs and only #3 was black. It was rich not oil soaked. I put a new set of plugs in and took it for a drive and performance is the same. Still has a miss up top.
Waiting for it to cool off and going to check #3 plug again.
If I slowly press the pedal down while driving it starts to accelerate smoothly and then it gets to a point beyond 50% throttle that feels like secondaries kicking in and that is when the miss starts to occur every time. Anything before that feels normal.
As far as the condition of the engine I know I did a compression test when I first bought it and I don’t remember the exact numbers but I do remember being skeptical about it being fresh and after doing the compression test changing my mind. From what I can recall the cylinders were all the same with the exception of one and it was only off by 5lbs.
I’ll have to get another compression tester and recheck them because mine it not holding pressure for some reason.
I have also had the pan off within the last couple of years and the inside of the engine was very clean, and there was cross hatch in the cylinders. It hasn’t been burning any oil since the intake work. Every time I check the oil level it has been the same since I did the intake. I believe it was leaking a bit at the valley into #7 before I did the intake because it used to use a little oil and would always blow a small plume of smoke upon initial start up, and that has all stopped since I‘ve done the intake and injectors.
I noticed the cold start injector is closest to #3 could it be causing this?
Maybe this injector is leaking, I'll have to check it out again. I know this injector is ticking like the others.
there will always be water in the tailpipe on start up because the superheated steam turns back into water and when u shut it off, some vapors return to water, and when u start it up, it blows out.
an excessive amount is indicative of a problem head gasket
High was 150 and the low was 135 dry.
They all went up with the wet test, highest was 160, lowest was 150.
Engine is showing some age for sure but not dead. Ohm tested all the wires and there fine.
#3 is still black and all the others are too clean as far as I am concerned so I think the #3 injector has a problem.
I pulled the connector off #3 at it killed the cylinder so If it is leaking it's not enough to fire at idle or anywhere else in the range.
Here's a pic of one of the new plugs with 300 miles on it, all but #3 look alike. White electrode looks like it's never been used.
And this is one of the old ones that were in prior to the intake R&R. I put these in 5 or so years ago when I first bought the car, damn there may be 20 or 30,000 miles on it. All 8 looked like this one. That is grey/white not tan.
