space saver spare rims needed for 200mph plus
Old Jan 1, 2007 | 03:59 PM
Carl Johansson's Avatar
Carl Johansson
Default space saver spare rims needed for 200mph plus
OK guys I know this sounds crazy but it turns out most of the guys running high speeds at Bonneville are simply putting the high speed tires onto the spacesaver rims.
so I have 1 - I need 3 more rims - anyone willing to help me out here?
(I know it doesn't seem to make sense - but it's the tech inspectors who put me onto this . The nice part is that it saves quite a bit of money - to be used for other things!)
Carl johansson
Old Jan 2, 2007 | 02:08 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Mine's taking up space, I'll probably never use it. Where do you live? It's pretty heavy.
I wouldn't go cheap on wheels for a 200mph car, but hey, it's your azz.
Old Jan 2, 2007 | 04:13 AM
xrcrx's Avatar
xrcrx
Where ya located. I've got one that I was plannin' to remove anyway.
Old Jan 2, 2007 | 09:56 AM
Carl Johansson
I wouldn't either - except thats the collective voice of hundreds of 200 mph runs made over the last 30 years - if they tell me thats the way to do it - you better believe I'm gunna listen to em! - they've been there , done that, got the red hat - and now volunteer their time to make sure newbies don't kill themselves by doing somerthing stupid!
Carl "I don't try to weasil my way through tech" Johansson
Old Jan 2, 2007 | 09:58 AM
Carl Johansson
I don't need the tire - just the rim - but I live in central california - I may need to head out to the local pick and pull - does anyone know if all GM spacesavers are the same size?
Carl
Old Jan 2, 2007 | 10:09 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
87 down, 16", later 17" alot more expensive/rare. (16's won't work on 89 up rotors.)
Old Jan 2, 2007 | 10:23 AM
SHINOBI-X's Avatar
SHINOBI-X
Where in central california Carl?
Old Jan 2, 2007 | 12:23 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
good luck
Old Jan 2, 2007 | 12:31 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Originally Posted by Carl Johansson
I don't need the tire - just the rim - but I live in central california - I may need to head out to the local pick and pull - does anyone know if all GM spacesavers are the same size? Carl
I'd try to get three from corvettes, just to make sure the bolt pattern is right.
Good Luck, but I'm keeping my spare....
Central California? ...is there some reason you can't you give us a city?
Larry
code5coupe
Old Jan 2, 2007 | 01:23 PM
Carl Johansson
Auberry - a small town in the mountains about 40 miles east of fresno!
Carl
Old Jan 2, 2007 | 01:24 PM
Carl Johansson
Good information. I'll stick with the 16's - easy enough to find the correct tire in 16".
Carl
Old Jan 2, 2007 | 01:25 PM
Carl Johansson
Larry
code5coupe
Cause I'm on the run? If my wife finds out where I am she might come and get me!
Carl "on the lam" Johansson
Old Jan 2, 2007 | 01:55 PM
Slalom4me's Avatar
Slalom4me
Carl,
Is the appeal of the spare the smooth steel face or the narrow width?
For larger diameter and less weight, the GTO spare works well
on the C4. Folks with the Z06 calipers find them useful. Might
not be quite what you need but I thought I'd mention it.
Old Jan 2, 2007 | 03:44 PM
Redvette_22's Avatar
Redvette_22
Carl johansson
I have two your welcome to have for free if you like.
Dennis
Old Jan 2, 2007 | 04:01 PM
Carl Johansson
Hey Ken,
it's the narrow width and I think they like the bead as well - the surface will be covered by moonies - screwed to the rim!
Carl Johansson
Originally Posted by Slalom4me
Carl,
Old Jan 2, 2007 | 04:02 PM
Carl Johansson
Thanks Dennis,
I may take you up on the offer. I'll let you know in a few days!
Carl J.
Dennis
Old Jan 2, 2007 | 05:23 PM
CentralCoaster
I believe my 85 spare is 16", will that work for you? I could ship it from San Diego, or leave it for you in Frazier Park, CA.
To space saver spare rims needed for 200mph plus
Old Jan 2, 2007 | 11:05 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Carl,
Now I know some drag racing folks were looking for GTO spares, but are you also using the tire? Is that even safe?
Old Jan 2, 2007 | 11:29 PM
Slalom4me's Avatar
Slalom4me
If you are asking me, I have a GTO spare for use at the intended
purpose - low speed, temporary replacement in the event of a flat.
It fits over the C5 Z06 front calipers on my car.
As for Carl
I don't need the tire - just the rim ...
I expect he'll use the rim and mount appropriate, narrow speed-rated
rubber for the Bonneville runs. On the salt, skinny is good.
Old Jan 2, 2007 | 11:38 PM
Grease Monkey
As for Carl
, less friction means higher top speed
