My trap speed dropped close to 1mph when I had other plugs in and came back up to "normal" after I installed the used cut-backs. These numbers were after correction of trap speeds for weather conditions.
I like to use a cut-off wheel on a Dremel for the base cut and first cleanup. Then a fine fingernail file finishes the job nicely.
I have just been investigating this. Either method that I have seen will help the combustion process. Rapidfire plugs actually come with the center electrode half exposed.
