Happy Newyears Everyone. I Have A 1985 Vette With The Tpi And I Was Would Like To Know If There Is A Way To Remove The Iat Without Taking The Top Part Of The Tpi Loose I Can See It Clearly But Not Sure How To Get It Out.
IAT/MAT. On my '88 this is screwed into the bottom of the plenum. You might be able to get at it, there's not much room. You could unplug it and leave it there if it's bad. The run wire and mount a new one in the air filter shroud.
Oh, the MAT. Yes, it's under the plenum. I haven't tried to take it out with the plenum still atached. I did however tried to connect the connector with the plenum on and it was a bastard. I would just take the plenum off to get to it and clean up around the intake manifold while your there.
new question how will my tpi run if i just unplug the iat for now untill i have the time to take it apart. an work on it i pick up the part just do not have the time to take the car apart to fix it.
Should run ok...it's not used for anything on a MAF car....but you'll get a "Service Engine" light....unless you remove it from the prom...
