I found this article interesting. It's Magnaflow's article on performance gains on a stock C-5 with H-pipe & stock Mufflers vs. with the same C-5 with X-pipe and high flow mufflers. It also lists the sound level measurements.
On my 93 I had long tubes, then straight pipes running back to stock mufflers with no cats or pre cats...I had an X-Pipe fabbed up and installed...I've had only 4 passes at the drag strip since and the results have not shown much...I will be going again on Jan. 14th so we'll see what happens then...I did this mod to try and pick up a bit more grunt out of the hole...nothing as of yet...I have not had it dynoe'd to check against previous numbers...I need to wait until the temps get back in the 90's for that...
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13
Can't quantify this, it's just a gut feeling. I think if the factory H-pipe was fully opened, then there would be zero difference between it and the X-pipe.
