Rear End Question
Old Sep 30, 2001 | 12:19 AM
mothersworry's Avatar
mothersworry
Default Rear End Question
I have a 1992 corvette six speed. How can I tell which rear end I have? :flag
Old Sep 30, 2001 | 01:01 AM
ANTI VENOM's Avatar
ANTI VENOM
Default Re: Rear End Question (mothersworry)
Its a dana 44...
Old Sep 30, 2001 | 11:59 AM
mothersworry
Default Re: Rear End Question (ANTI VENOM)
How can I be sure? Are there any codes on the car that will inform me? :flag
Old Sep 30, 2001 | 07:26 PM
ANTI VENOM's Avatar
ANTI VENOM
I've never been much for codes, but if the car came with a six speed it is a 44. Besides being a little beefier than the 36 I couldn't really tell you how to tell the difference and I have one of each. Some of the other guys I'm sure can tell you specifics. Hope this helps.
Old Sep 30, 2001 | 08:08 PM
SteveElliott's Avatar
SteveElliott
If the car is stock, it does have a Dana 44. There are numbers stamped on the housing that gives you the date of mfg. along with the ratio. It's located on the bottom so you can see it if you clean the area well. Also, the rear cover is different then the Dana 36's used in automatic cars. :cheers:
Old Sep 30, 2001 | 09:01 PM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
Look under your center console lid and you'll see a list of the rpo codes for your car. Since you have a ZF6 tranny , you'll find rpo GM3 which is the Dana 44 rear end with 3:45 gears, if it is the original unit. :D
Old Sep 30, 2001 | 09:40 PM
mothersworry
Thanks guys that helps alot
To Rear End Question
