L98 Build up questions
I will agree. I would start with the exhaust. After installing a good set of longtube headers, cat, and catback mufflers....you will be more than half way through $2000. You MIGHT be touching at 300hp. More significant when you increase the intake airflow.
And to approach the type of horsepower you are looking for, you'll need a new intake set up, heads, and cam for sure, along with a custom tune. Start talking to tuners now
http://www.jkvette.cz28.com/whats_new_3.html
If your car is an automatic, a stall converter is a great bang for the buck mod. Next, tires would be another great mod. I guess my mod plan for your car/budget would look like this:
Headers, high flow cats, and a catback. Depending on what you choose, this can knock out your entire $2,000 budget if you let it.
Next, I would probably do a converter if you have an auto. If you are a stick shift car, skip this step.
1.6 roller rockers are a great mod for the L98, and should yield a decent gain.
A custom tune from one of the vendors here on the forum.
If you have any cash left, a nice set of drag radials would probably kill the budget.
with much of the above... One thing I learned in my younger years w/ building hotrods/fast cars... don't forget about the stop when putting in the go.
IMHO the stock brakes on our years (mine is a '90) are a bit lacking. None of this is cheap but it sure would suck to spend a few $K on making a car go faster & then having it bent or worse totaled out due to poor brakes.
Options when I did my first brake upgrades were limited but now you have more options at better prices, ie C5 brakes etc.
Good luck w/ your build though. Take a few small steps w/ the funds you have & learn how to drive the thing... there is a LOT of potential there if you know how to tap into it.
If you are likely to go with the TTs that decision needs to be made before selecting heads & cam.
Pick up some books by Vizard, Emanuel, and LPE on engine building for some ideas and details on what is involved.
Link to the Description and price
and then pick up some long tubes and youd have a good flow through the motor, just an idea, i really like those heads for some reason
