GM Bosch Injector connector receptacles
CI 5 & 8 Veteran
Where is the best place to get a set of replacement crimp receptacles for GM Bosch injector connectors. I am re-wiring my RamJet 502 for an Accel Gen VII DFI system.
Bullshark
Bullshark
St. Jude Donor '10-'11-'12-'13
Believe it or not, my local Carquest was able to get me the female ALDL terminal end connectors I needed for my '87 (which I didn't expect at all), so you might try your local auto parts store. Or, a maybe a boneyard?
CI 5 & 8 Veteran
Don't know if you had see THIS yet.
Bullshark
Yes - definitely different. I mentioned it because it seemed like a fairly uncommon piece that Carquest was actually able to get.
I wonder if the Stealership would be able to get anything like that?
