Still have a problem! Opinions needed.
Old Jan 3, 2007 | 09:53 AM
pletner's Avatar
pletner
Default Still have a problem! Opinions needed.
Hi all! I have a problem with my '92 that I can't figure out. When I accelerate slowly my engine feels/sounds like it is missing. As I continue to accelerate (without changing my throttle position) the engine will suddenly come to life and run fine, like turning on a switch. This only happens when the car is in closed loop. I have replaced the fuel filter, injectors (checked the fuel pressure it's ok), plugs, plug wires, opti-spark, waterpump, coolant temp sensor, intake air temp sensor, manifold absolute pressure sensor, throttle position sensor, O2 sensors. I've used two different scanner tools and EVERYTHING reads within factory spec. There are NO error codes. At wide open throttle this thing runs like a scalded dog. Any ideas?
Old Jan 3, 2007 | 10:18 AM
Casethecorvetteman's Avatar
Casethecorvetteman
Have you checked for vacuum leaks?
Have you cleaned out the throttle body and the IAC path?
Check EGR function to make sure its not leaking or allowing exhaust gas to pass when it shouldnt.
Check the CCP is functioning correctly.
Old Jan 3, 2007 | 10:23 AM
mikey whipreck's Avatar
mikey whipreck
also stuff that wouldn't show upin the tests you did.
Old Jan 3, 2007 | 11:23 AM
pletner's Avatar
pletner
1. Yes, no leaks 2.EGR has been removed and chip calabrated for it. 3. CCM is working fine
Old Jan 3, 2007 | 12:06 PM
pletner's Avatar
pletner
Sorry:o I thought you were talking about the CCM. Please excuse my ignorance, but, what is the CCP?:o
Old Jan 3, 2007 | 12:08 PM
Casethecorvetteman
Charcol canisiter purge. Connected to the right hand side of the throttle body under the PCV connection.
Did you remove the A.I.R. system as well?
Checked for exhaust leaks before the O2s?
Old Jan 3, 2007 | 12:12 PM
runner140*'s Avatar
runner140*
When was the last time you changed your fuel filter?
Might be a place to start.
Old Jan 3, 2007 | 12:15 PM
pletner's Avatar
pletner
I removed the A.I.R. system, I've checked for leaks before the O2's and I can't find any. What should I look for on the CCP?
Old Jan 3, 2007 | 12:27 PM
Casethecorvetteman
He states that in his opening post mate.
Do you have a service manual??
The charcol canister is in the back of the car, on the right hand side. It connects to a solenoid which is located towards the front/right of the intake manifold, from there it connects to the throttle body on the right hand side. Pull that hose off at the throttle body and block both the hose and the fitting on the throttle body. If this makes some sort of radical improvement then look at diagnosing the system.
Old Jan 3, 2007 | 12:35 PM
pletner's Avatar
pletner
Thanks! I'll try that. I've got the service manuals, but I didn't think to check the charcol canister.
Old Jan 3, 2007 | 01:09 PM
Casethecorvetteman
If that leads nowhere id try the stock chip if you still have it.
The fact that everything reads within factory spec on a scan tool doesnt mean much at all really, its no indication that every system is functioning as it should. There is a fair few things that can work incorrectly and the sensors can still give readings within spec.
Old Jan 3, 2007 | 02:09 PM
pletner's Avatar
pletner
Well, no luck. I blocked off the CCP line and the throttle body line and it didn't make a difference. I tried the stock chip and it too didn't make a difference. I did however unplug the intake air temp sensor and it runs fine.? (this by the way is new)
Old Jan 3, 2007 | 02:16 PM
serge's Avatar
serge
From: Olympia Washington 91 Z07 Coupe, 6spd, Borla Exhaust, Perf. Ignition, K&N Filter
this will sound really stupid and im sorry if im just wasting your time
have you thought about the gas you are using, are you using 92 and is it a high quality gas, like shell, texaco or chevron? sometimes bad gas can really cause some temporary and permanent problems like bad acceleration and pinging, on hills and high altitudes
Old Jan 3, 2007 | 02:20 PM
pletner's Avatar
pletner
Serge, thats not stupid and your not wasting my time(I appreciate everyone's input). But I am using chevron premium.
Old Jan 3, 2007 | 08:41 PM
Lichen's Avatar
Lichen
Mods? With my retarded Hotcam, it's like a switch turns on at 3000 rpm.
Old Jan 3, 2007 | 11:28 PM
Casethecorvetteman
Check the wiring to that, where have you got the IAT located? (Not in the airbox i hope, cause it doesnt belong there)
Im not sure if a 92 will run in closed loop with that unpluged though. If it stays in open loop, that explains why it makes a difference.
Mods are listed in his sig on first post.
Old Jan 3, 2007 | 11:52 PM
pletner's Avatar
pletner
My IAT is in the stock location, I've checked the wiring and it's o.k. I think it's running in open mode with it unplugged, thats why it runs better.
To Still have a problem! Opinions needed.
Old Jan 3, 2007 | 11:59 PM
Casethecorvetteman
Yeah if thats the case it doesnt say much at all either really. It certainly doesnt say the sensor is bad if its reverting to open loop without it, it could be other things too.
Old Jan 4, 2007 | 12:21 AM
pletner's Avatar
pletner
Yeah, that's why this is about to drive me crazy,I believe it's either fuel or electrical related, but so many things contribute info to the ECM it must be something I haven't checked. What else am I missing?
Old Jan 4, 2007 | 12:45 AM
Casethecorvetteman
Start from the top and work through it all mate, check everything. If you can get a hold of a couple O2s that you know work, swap them out and see if that helps.
Check the coolant temp sensor.
Are you getting any smoke of any kind?
