Fuel Presure Regulator Question
Old Sep 30, 2001 | 02:21 PM
BOB'S C6's Avatar
BOB'S C6
C6 of Year Finalist (stock) 2019
Default Fuel Presure Regulator Question
I took a fuel pressure reading and I'm reading 26lbs at the fuel rail. If I disconnect the vacuume line it goes up to 38lbs. Is this normal? What would happen if I leave the vacuume disconnected? If I install an adjustabe regulator what pressure should I set it at for a stock L-98 engine?
Old Sep 30, 2001 | 02:30 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Fuel Presure Regulator Question (Silver85)
That is normal behavior; vacuum line off gives WOT vacuum reading. You should set the AFPR to the stock WOT reading. Then tune fuel pressure from this base setting. Do NOT leave the vacuum line disconnected for normal driving.
