2.02/1.60 valves?
Old Jan 4, 2007 | 07:38 PM
6spd95's Avatar
6spd95
Default 2.02/1.60 valves?
202/1.60, Can they be used on stock LT1 heads? I heard somewhere that the biggest valves that fit stock seats are 2.00/1.56. can anybody confirm this??
Old Jan 4, 2007 | 08:00 PM
Ttime's Avatar
Ttime
I'm not sure about stock heads and I heard the same but don't have first hand experience . But I know Trick Flow has a set.
Old Jan 4, 2007 | 10:42 PM
VenkmanP's Avatar
VenkmanP
Yes, with new seats.
Old Jan 4, 2007 | 10:52 PM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
The stock heads that I've looked at have the 1.60 valves cut down to 1.56 or 1.55. Never seen one that had a real 1.60 valve. Just no room.
Old Jan 4, 2007 | 11:29 PM
VenkmanP's Avatar
VenkmanP
pretty much all the big name LT1 porters offer both 1.55/56 and 1.60
For instance:
http://eportworks.com/LT1LE3.htm
Old Jan 4, 2007 | 11:50 PM
Zix's Avatar
Zix
Here's a picture of my stock LT4 castings with 2.055/1.6 valves and a lot of combustion chamber work...
Old Jan 4, 2007 | 11:51 PM
STL94LT1's Avatar
STL94LT1
My CNC Cylinder Heads LT1 heads have 2.0/1.57.
Old Jan 5, 2007 | 10:20 AM
6spd95's Avatar
6spd95
well replacing the seats is out of the question, that would be to much money. So I guess I'm going with the 2.00 and 1.56 . one reason I wanted to do this is because these heads have had previus valve jobs and the valves are begining to sink. by putting bigger valves will bring them back up a little.
Old Jan 6, 2007 | 04:01 AM
5abivt's Avatar
5abivt
there are LT4 castings with 2.08 and 1.65s out there
Old Jan 6, 2007 | 09:29 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I have the 2.02-1.6 combination in factory LT1 castings.
Old Jan 6, 2007 | 05:07 PM
Bruce's Avatar
Bruce
my LT1 heads got 2.02/1.57
To 2.02/1.60 valves?
