1.6:1 rockers
Old Jan 6, 2007 | 12:08 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
You can get the Comp Cams ProMagnum RRs in either self aligning not not, though if you want to upgrade the rocker studs to 7/16" they are only available in non self aligning.
This presents no problem though as the total price works out about the same and you need to pull the stock non-hardened guide plates (on Al head L98s) anyway.
BTW, the Comp Cams #981 springs (seat 110lbs at 1.70") work well with a stock cam & 1.6:1 RRs on my '88 L98.
Old Jan 6, 2007 | 01:27 PM
STL94LT1's Avatar
STL94LT1
Originally Posted by RED86RAGTOP
I'm also interested in this set-up. I have to do the valve seals, so I figured I might as well change springs and go with the 1:6 rockers too. Which brand rockers are recommended? And does GM sell a kit with the lt4 springs, locks, and retainers or do you have to get them seperately? I did a little looking around on line and could not find a kit that included everything. Any help appreciated
I don't hink GM sells the LT4 valve springs/locks/retainers as a kit. But, here are the individual part numbers.
LT4 springs #12495494
Retainers # 12495492
Locks #12495503
Call Dallas at Van Devere Olds for a good deal. 1-800-362-9494
Old Jan 6, 2007 | 03:54 PM
Trog's Avatar
Trog
w/ much of the above. My '90 is alum 113 heads & I did run stock springs, non self aligning Harlin Sharps, 7/16 studs & stock guide plates/pushrods for a few years.
However, when I did a valve job I found the following:
stock springs were toast, about 60 psi seat pressure
stock guide plates are NOT hardened & had began to wear
stock pushrods ARE hardened & I used them over.
New springs, ditch the rotators, machine valve stems & spring seats for good seals, new hardened guide plates. Now things are
Old Jan 7, 2007 | 09:14 AM
RED86RAGTOP's Avatar
RED86RAGTOP
Ok, seems like I've got the rockers and springs down, but what valve stem seals are the best to use?
