Temp gauge
Old Jan 5, 2007 | 11:00 AM
arandy's Avatar
arandy
St. Jude Donor '08
Default Temp gauge
Does replacing the temp sender unit correct the 30 degree offset that many of us have on our analog gauge? I hate gauges that read wrong.
Old Jan 5, 2007 | 11:44 AM
SunCr's Avatar
SunCr
Maybe - maybe not. Basic test is to disconnect the harness from the sender. That should peg low. Ground the lead and it should peg high. If either fails, the wiring has too much resistance or the Cluster is bad.
Old Jan 5, 2007 | 12:43 PM
arandy's Avatar
arandy
St. Jude Donor '08
Is this true with the analog gauge in a 95, or just the digital gauge in the earlier dash panels?
Old Jan 5, 2007 | 01:27 PM
RRT vette's Avatar
RRT vette
On the (84-89) the temp sender is in the right head between 6 and 8 spark plugs. On the 90-91 I believe the analog sender is in the same place and the digital readout is from the CTS in the intake manifold.
The LT1 cars, the analog sender is in the left head between 5 and 7 spark plugs. The digital readout is from the CTS in the water pump.
Do as SunCr suggested to test this.
Old Jan 5, 2007 | 01:41 PM
arandy's Avatar
arandy
St. Jude Donor '08
Thanks guys. RRt my 95 is your verts twin except I have 18" chrome ZO6 rims.
Old Jan 5, 2007 | 01:56 PM
RRT vette's Avatar
RRT vette
Very nice. You don't see many yellow's with a black top.
Old Jan 5, 2007 | 06:12 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
What do you mean by "the 30 degree offset that many of us have"? The analog gauge isn't linear. The midpoint of the gauge is not the average (180*) of the two end points (100* & 260*). It's closer to the recommended operating temperature; in the case of the LT1 that's around 220* Just want you to make sure before you start spending time and money on a fix that isn't required or won't do any good.
To Temp gauge
