4x3 overdrive woes.
I DID, however, put the new relay in place and unfortunately it did not change the performance and the Woes continue.
CC, I am glad you are here. Seems if you wanna talk about Blower Packages everybody has an opinion, if you want to talk about this obscure 4x3 OD unit.....the Crickets seem to chirp. It looks like one of those deals where with your help, I have to become a 4x3 O/D expert due to the alternative being getting the dealer to put in a new one at eleventybillion dollars.
All the threads I googled using the keywords "Corvette pressure Switch" (of course this thread was the number one return) terminated with the original poster leaving to put in a Switch and solenoid. They never reported back after that.
He told me...and I am writing it down for future reference.
The Clutch plates will be exposed once you drop the pan to install the pressure Switch. If the plates appear dark brown or black then it the OD unit is fried. If they are still reddish Brown you should be ok.
He also told me that there was no way to check the pressure switch without conducting a destructive test. Sorry CC, He didn't like the Air pressure idea.
Another tip from a retired Vette Guru from Anaheim, Gary Leonheardt, Go to Pep boys and purchase an oil pan drain plug. This is a plug that has a two sided mount with an o-ring (use RTV instead). You punch or drill a hole in the bottom of the pan. Then install the drain plug. Now, you can drain the ATF and refill it every time you change your Motor oil. Only a Quart or so will come out.
The Common theme here from everybody....and I have spoken to quite a few about this 4x3 OD unit....is regular maintenance, meaning clean fluid and filters. The fact that the General failed to provide this info is what is killing these units prematurely. That coupled with the fact that there is no dipstick under the clamshell means the unit is usually neglected.
More info as it is gathered.
It seems like you're hesitant to pull the pan. Just pull the pan already, it takes 5 minutes. Might take some effort to pop it loose. See if you can get a blade into the sealing flange to seperate it, or try a mallet and wood block. If you have to pry on the pan gasket surface, make sure it's with a wide tool to spread the force out, otherwise you'll bend the pan or damage the sealing surface.
It would be pointless to replace the pressure switch and seal everything up without having identified the cause. For that reason you have to test the original pressure switch anyways.
While the pan is off, you will then also check the ohms across the solenoid, or just send power to the solenoid to test it, using the diagnostic mode and bypassing the pressure switch.
There is not a lot of fluid involved when draining and with a wide drain pan, you should easily catch all of the fluid when you take the pan bolts out. Leave one or two bolts in the highest part of the pan with just a couple of threads holding the screws and pop the seal at the lowest part. That will allow most of the fluid to drain out and won't allow the entire pan to drop off.
(B.)It seems like you're hesitant to pull the pan. Just pull the pan already, it takes 5 minutes. Might take some effort to pop it loose. See if you can get a blade into the sealing flange to seperate it, or try a mallet and wood block. If you have to pry on the pan gasket surface, make sure it's with a wide tool to spread the force out, otherwise you'll bend the pan or damage the sealing surface.
(C.)It would be pointless to replace the pressure switch and seal everything up without having identified the cause. For that reason you have to test the original pressure switch anyways.
(D.)While the pan is off, you will then also check the ohms across the solenoid, or just send power to the solenoid to test it, using the diagnostic mode and bypassing the pressure switch.
(B.) I am hesitant to pull the pan, your observant and patient. Mainly because I can't get up under the car, No real Jack at the moment. My Bud has a lift, I just have to wait for it to be open. We'll get there Friday.
(C.) That is True. I'll try to figure out what you are saying when I get the switch. Sorry, please don't lose patience with me. I know your mind you are thinking that it is so easy, but with me I have a hard time just pulling **** apart when I haven't a clue what I am trying to do. This instance I really have no choice and with your gentle prodding I'm getting there.
(D.) Checking the ohms across the solenoid from the inside will be the proof in the pudding. I can't do this properly and since the opportunity passed by last Friday. I have to wait.
Thanks again. You are Huge I really really appreciate you.
I'm not questioning to be a Jerk, rather I'm trying to learn.
I recall reading about other 4+3 owners using synthetic ATF like Mobil-1 (maybe it was Scorp??). Not sure if that's a good idea or not, but the synthetic fluid might help if the tranny is subject to extreme use.
If you really want to install a drain plug for frequent fluid changes, I would not use RTV to seal that plug assembly. Either get a nut that matches the threads of the drain plug and braze it to the pan just like the block oil pan or braze the drain plug female portion. Be careful to not use a lot of heat so the pan won't warp or maybe risk burning thru the thin sheet metal.
Learning about the 4+3 is important for the owners to get a better understanding of this tranny. There are those on the Forum who don't seem to care for the tranny, but they do work if you pay attention to them. Reeves Callaway didn't seem to have issues with them as he used them behind his twin-turbo motors
Also I have photos of the pressure switch with p/n, and the whole underside of the overdrive on my home pc. There's probably some universal pressure switches that'd work as well.
http://www.rbartick.com/vetwork/pics/clutch_015.jpg
I doubt your switch is bad. I tried to replace that switch on mine before I pulled my O/D.
See here for some pics:
http://www.rbartick.com/vetwork/clutch.html
It's no big deal to do.. disconnect the TV cable, remove the long bolts, and make absolutely sure you don't lose track of any ball bearings!
If the OD just stopped working all at once with no warning, why would you think mechanical failure over electrical???
I had the OD light come on, with no overdrive. It happened a few times and was really frustrating. I too felt that "Oh no, it finally went!" feeling in the pit of my stomach.
It turned out that the electrical connector at the OD was coming loose. I cut the plastic connector off (it was partially melted anyways), got a spade connector from NAPA, spliced it and reconnected it. I used some vacuum hose to put over the wire and the connection on the OD. I think it was something like 5/8" inner diameter but I'm going from 2 years memory on this.
The OD has been fine ever since.
BTW, these units get a bad rap. If maintained, every 10k or so fluid and filter changes, they'll last.
These units earned their bad rap. I haven't come across an owner of an 84-85 unit that still has the original unit. It seems most were dead by 25-30K miles. That aside, I enjoyed driving it with the stick shift and the auto kick-down. (the only cool part about an automatic)
