front parking brake cable needed
Old Jan 7, 2007 | 12:33 PM
JohnUKVetteNut's Avatar
JohnUKVetteNut
Default front parking brake cable needed
Hi All
My 94 needed new parking cables all round and Donhall found me some rears ( thank you) but I cant find any new front parking brake cable suppliers? any ideas PLEASE, my one on the car has broken so it would be difficult to get a copy made and I think due to the metal sleeve fitted to these I might find it v.difficult here in the Uk
John UKVEttenut
Old Jan 7, 2007 | 12:56 PM
VenkmanP's Avatar
VenkmanP
Available new from any GM dealer.
Old Jan 7, 2007 | 03:01 PM
jfreeman's Avatar
jfreeman
6th Gear
Default C4 Front Parking Brake Cable
Chevy has discontinued front Parking Brake Cable for 89 - 96 C4s. None of the usual sources have any, so I too would be interested in any help out there in finding this part.
Old Jan 7, 2007 | 04:31 PM
bogus's Avatar
bogus
I had to reread this post... there is no such thing as a "front parking brake cable." At least not for a Vette... an old Saab, perhaps, but not a Vette.
Depending on the situation, the cable might be saved. I would suggest removing it from the car, then hanging it on the wall and spraying it with a good penatrating oil. That might just get the job done...
Otherwise, you may want to contact Jason at www.vette2vette.com for a good used part.
Old Jan 8, 2007 | 06:21 AM
jfreeman's Avatar
jfreeman
6th Gear
Thank you for your suggestion. You are right, "there is no such thing as a "front parking brake cable." At least not for a Vette" The part has been discontinued. You might want to go to this link to see a non-existent discontinued front parking brake cable.
http://www.artscorvetteparts.com/par...f-d2f2e29d06c7
Old Jan 8, 2007 | 06:32 AM
94z07fx3's Avatar
94z07fx3
Originally Posted by JohnUKVetteNut
Hi All
John UKVEttenut
I know this will sound crazy at first but I suspect that if you take your broken cable to a bicycle shop (shoppe?) that they will be able to make a custom one for you.
Old Jan 8, 2007 | 04:29 PM
VenkmanP's Avatar
VenkmanP
When I posted, I looked up "front brake cable" in the gmpartsdirect catalog, and I got a P/N 10113015 which is described as "Parking Brake Cable" for 90-96, and is in stock.
Old Jan 8, 2007 | 09:15 PM
bogus's Avatar
bogus
the description is misleading. It is actually the FORWARD parking brake cable. This is the one from the lever to the lateral rear cable.
Old Jan 10, 2007 | 07:26 AM
jfreeman's Avatar
jfreeman
6th Gear
Thank You. That is the part number, however, although many companies show the part as in stock on their websites, a call to confirm seems to always result in the part being not available. I continue to diligently pursue my thus far unsuccessful search.
Old Jan 16, 2007 | 03:30 AM
VenkmanP's Avatar
VenkmanP
I was just shopping for something else and noticed that partsamerica carries the front cable. $7
Old Jan 16, 2007 | 08:38 AM
Tom Piper's Avatar
Tom Piper
Over the years, a lot of parts were discontinued for the C2 Corvette (although, you would be amazed how many parts are still available at a GM parts counter).
For the C2, the after-market has stepped in and just about everything is available somewhere today.
You can just about get every part to build a C2 from scratch today -- I think the only part not being done is the "bird cage."
You can now buy a complete brand new C2 frame done with the original GM tooling for about $5K.
So, I expect that someone will step in and make the front cable at some time.
I would try Van Steel or the several vendors that deal with making aftermarket brake parts specifically for the Corvette -- Like Vette Brakes and Products.
Tom Piper
Old Jan 16, 2007 | 09:51 AM
VenkmanP's Avatar
VenkmanP
Aftermarket is available already.
To front parking brake cable needed
