To reset the oil light, put the key in the ignition and turn to accessory setting (but do not start the car) Push the English/Metric button twice and then push and hold the "Gauges" button. The "Change Oil" light will flash for about 15-20 seconds and then go out. Release the button and turn key off.
2. Press “ENG MET” on the Trip monitor Then, within five seconds,
press it again.
3. Within five seconds, press and hold
“GAUGES” on the Trip Monitor. The “CHANGE OIL” light should flash.
4. Hold the “GAUGES” button until the “CHANGE OIL” light stops flashing
and goes out.
This should take about ten seconds.
When the light goes out, the monitor is reset. If the monitor doesn’t reset, turn the ignition off, then try again.
i've went through the drill as listed in the manual about a hunnered times and the light shines on. any clues on this one ?
Does the light flash? If it flashes and is not going out, you may not be holding the button down long enough, it does seem to take forever when you are staring at the light flashing. Just make sure the light stops flashing before you let go of the button.
I have not been able to get mine to start flashing. This is the first time in 16 years that it has not worked so i guess it was over due.... sorry if i got off the original subject...
