Force 10 Brakes
Old Oct 1, 2001 | 12:38 AM
92TripleBlack's Avatar
92TripleBlack
Default Force 10 Brakes
Anyone use these brakes from http://www.stainlesssteelbrakes.com ? They look mean but are they worth the extra $600 over a C5 or big brake upgrade?
92TripleBlack :cheers: :smash:
Old Oct 1, 2001 | 03:31 AM
No Ordinary 91's Avatar
No Ordinary 91
Cruise-In III Veteran
Default Re: Force 10 Brakes (92TripleBlack)
well a 4 piston caliper will always have its advantages over a 2 pison floating caliper and wheter or not its worth the extra money will really depend on how you plan to use your car. To be competative in racing you would definately want to go with the Force 10, if you are just cruising the local hangout spot friday night you probably sould never need the extra braking power over C5 or J55, or if you got the cash and just want to be different then force 10
Old Oct 1, 2001 | 08:51 AM
Tom Piper's Avatar
Tom Piper
I looked at them. They have two four piston calipers. If I remember correctly, one has 43 mm pistons and one has 48 mm pistons. Both come with a new master cylinder and rotors.
Tom Piper
[Modified by Tom Piper, 7:46 AM 10/2/2001]
Old Oct 1, 2001 | 09:32 PM
92TripleBlack
Default Re: Force 10 Brakes (Tom Piper)
That's right. One is a 43 mm 4 piston setup and the other is 48mm with 4 pistons. The GS system is twin 38mm pistons and the C5 had twin 40mm. Anyway you look at it they are LARGE. The first system is $1200 complete and the second is $1400. They claim a 60-0 of 93 feet with the second system. Has anyone used it? Is it worth the $$$? Can you use Eradispeed rotors with the calipers?
Old Oct 2, 2001 | 08:05 AM
Tom Piper's Avatar
Tom Piper
If I am not mistaken, the design of the calipers is almost exactly like the '65 through '82 Corvette calipers, except the Force 10 calipers are made of aluminum.
When you think about it, for $1200, the Force 10 setup gives you more for your money than the C5 upgrade from Vette Brakes for $1000. However, with the Vette Brakes setup, you could probably buy replacement parts locally.
Tom Piper
[Modified by Tom Piper, 7:49 AM 10/2/2001]
To Force 10 Brakes
