I'm considering running Redline D4 ATF transfluid. Are there some negatives about synthectics or this particular brand? If synthetics are not so good what is the best non-synthetic?
Thanks!
Anything special about filters for 700r4's? My wife recently bought a 1992 auto coupe and I was making a list of fluids/filters/whatnot to begin a documented maintenance.
Oh and is there an easy way to change all the ATF?
From: 2003 Points Champ Great Lakes Corvette Challenge; 2006/2007 Winner MSD True Street
Your dealership should have one of those trans flush machines.
It takes all the old and replaces with new.
I know some quick change oil places have those as well but that's up to you if you know a good one.
As you know, dropping the pan, with a filter clean/change, only changes 1/2 the fluid.
I personally alternate the two on my truck.
My corvette does not apply as I drop the trans and rebuild it on a regular basis.
