Questions regarding siamesing the plenum...
Old Oct 1, 2001 | 01:49 AM
BobMachus's Avatar
BobMachus
Default Questions regarding siamesing the plenum...
I have spent a few hours today porting and polishing my TB. Then I started on my plenum. Yikes is that alot of work with a die grinder! Tomorrow I am gonna put in a mill to hog out the big stuff. Now to my question...
I am contemplating siamesing the runner openings in the plenum. Then I was gonna port and polish the plenum end of the runners. Any thoughts on whether this would be a good idea or not? I can't think or any reason this would be bad, can you?
Thanks, Bob
Old Oct 1, 2001 | 03:23 AM
No Ordinary 91's Avatar
No Ordinary 91
Cruise-In III Veteran
Default Re: Questions regarding siamesing the plenum... (BobMachus)
hey hows it going, i am planning that mod soon, gotta wait to get a spare intake so i don't have to park the car. Check out the thread about that from a few days ago, i will see if i can find the link
Old Oct 1, 2001 | 03:26 AM
No Ordinary 91
Default Re: Questions regarding siamesing the plenum... (No Ordinary 91)
here you go bob
check it out http://forums.corvetteforum.com/zerothread?id=153200
Old Oct 1, 2001 | 04:23 AM
89TripleWhite's Avatar
89TripleWhite
Default I can save you the hassle
If you have the money.
Arizona speed and maring sells em for 425$
Old Oct 1, 2001 | 11:55 AM
BobMachus's Avatar
BobMachus
Default Re: I can save you the hassle (89TripleWhite)
Actually..I was asking about siamesing the runner holes in the plenum, not the intake base (but that's coming!). Is there any reason that any of you can think of not to cut out the walls between the paired runner openings in the plenum? Thanks, Bob
Old Oct 1, 2001 | 12:01 PM
91Yellow1's Avatar
91Yellow1
Default Re: I can save you the hassle (BobMachus)
I too am curious about this as I plan to tear the car down within the next month or so (depending on weather).
[Modified by 91Yellow1, 10:02 AM 10/1/2001]
Old Oct 1, 2001 | 12:31 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
When I did my plenum I fluted the upper runners and opened up the plenum holes to match plus continued the fluting into the plenum.
If you are going to siamese the plenum, I suggest you extend the effort into the upper tunner flange, and round the separation in the flang to provide a smooth air flow transition. Of course you can take a sanding drum to the stock runner gaskets to match em up.
I see no reason to not siamese the plenum and upper runner flange. It just shortens the runner length a little (say ~1") and increases the effective plenum volume.
Old Oct 1, 2001 | 12:41 PM
BobMachus's Avatar
BobMachus
Default Re: I can save you the hassle (65Z01)
That is what I thought, just shortens the runner length by probably less than 1", but has got to help air flow as those ribs in the plenum look like huge obstructions. Yeah I was planning on doing alot of blending/smoothing of the flange on the plenum end of the runners and on the small amount of dividing wall that there is. Anybody else wanna chime in?
Bob
Old Oct 1, 2001 | 10:25 PM
KYVette90's Avatar
KYVette90
I did this to my 90 last week. I cut down the EGR bumps in the front of the plenum and siamesed the plenum runner holes. I angled and rounded the walls that meet with the runners. I also contoured the runner openings and cut out a little of the divider between the runner tubes. You can get a whole set of oversized tpi gaskets from TPIS for $18. I've noticed that the engine reaches high rpms a lot quicker. I also removed my cats at the same time so that probably had a lot to do with the performance increase. I have not had a single problem from the porting though. :smash:
Old Oct 1, 2001 | 11:05 PM
pablocruise's Avatar
pablocruise
I did this a coupla weeks ago also. If you think the upper is tedious, wait till you attack the lower! Wow it was a PITA but I did it. If you really stop and think about it, the work on the upper may not be necessary but then again, more is better(?). When my new motor is fully broken-in, I will do some runs to redline. It in theory should redline alot higher now.
Old Oct 1, 2001 | 11:35 PM
Aggravated4life's Avatar
Aggravated4life
Default Re: Questions regarding siamesing the plenum... (89 Paul in cal)
Are you taling about cutting the wall down at the TB bores itself? Ive seen that done in a TPIS catalog...they siamesed the opening to the TB bores...however, look at the back of your TB and see where the gaskets cover..dont want to cut the middle wall down and find out the gasket is the only way to seal the back where the bores are,b from memory, this shouldnt be a problem.
Bt do check that first before cutting the middle wall down.
As for siamesing the runner holes themselves, thats fine...you can cut the walls down on the sides and open them to gasket size.You can also cut your gaskets siamese and slightly port back the runners themselves to form a "C" to sort of "divide" the incoming air into the runners, then just leaving them flat as they are.
May not do any real peformance gains but who knows? The more air you can fill into that plenum and runners can only help.
To Questions regarding siamesing the plenum...
