My rear end
Old Jan 8, 2007 | 01:12 PM
Bulldog Steve's Avatar
Bulldog Steve
Default My rear end
So my rpo code says i have a performance rear end. What is the diff. between this and any other rear end.
Steve
Old Jan 8, 2007 | 01:18 PM
Pete K's Avatar
Pete K
If you have an automatic trans, and it is a coupe, 2.59 is the standard rear ratio. 3.07 is the performance ratio.
Old Jan 8, 2007 | 01:19 PM
RRT vette's Avatar
RRT vette
3.07 is G44
Old Jan 8, 2007 | 02:53 PM
C4Techie's Avatar
C4Techie
It has to do with the rear axle gear ratio. RPO #G92 says, "Axle, Rear, Performance Ratio." Because different years, transmissions and even body styles, in some cases, had different standard ratios, the "performance ratio" varies, also, and is not a specific ratio. The one ratio that can't carry the "G92" label is the 2.59:1. There are probably others, too. "G92" means that the gear ratio is lower than the standard equipment gears, whatever they may have been for that particular car. There will be another "G" number on the RPO tag that will specify the actual ratio.
Old Jan 8, 2007 | 06:25 PM
Z-07 freak's Avatar
Z-07 freak
From: Why are there squished peanut butter cups in my underware?
What C4Techie said.
To My rear end
