Mounting MSD Box
Old Jan 8, 2007 | 09:32 PM
MyWhite93ette's Avatar
MyWhite93ette
Default I need a place to mount my MSD Box
I bought a MSD6AL box and I`m looking for good safe place to install it. At this point I`ll listen to all options. Thanks
Last edited by MyWhite93ette; Jan 8, 2007 at 09:54 PM. Reason: need to reword the title
Old Jan 8, 2007 | 11:16 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
I installed mine in front of the overflow bucket for the radiator. There it was in cooler air, and dont forget to bypass the tach filter so your tach works.
Old Jan 8, 2007 | 11:38 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Here ya go:
Old Jan 8, 2007 | 11:39 PM
NitrousSam's Avatar
NitrousSam
Default Lots of places
I have mine in the passenger side under the dash so I can change the rev limited chip easily and get to the timing retard box.
NitrousSam
Old Jan 9, 2007 | 12:32 AM
dustmann's Avatar
dustmann
Default Msd
I put my MSD next to the battery on the fender.
Old Jan 9, 2007 | 01:02 AM
Trog's Avatar
Trog
Left fender right in front of the battery, mounted vertical w/ stainless screws to the plastic inner fender. Wiring then can go right up to the distributor.
Old Jan 9, 2007 | 03:23 AM
bigwave71's Avatar
bigwave71
mine is in front of the overflow tank.
Old Jan 9, 2007 | 06:38 AM
JoBy's Avatar
JoBy
I made a bracket and put it behind the battery.
Old Jan 9, 2007 | 07:26 AM
LD85's Avatar
LD85
Old Jan 9, 2007 | 08:48 AM
MyWhite93ette
I had my first box in front of the overflow tank. It must have gotten wet and it burned out. Can it get wet?
Old Jan 9, 2007 | 07:13 PM
MyWhite93ette
can the msd box get wet?
Old Jan 9, 2007 | 07:25 PM
_twisted_'s Avatar
_twisted_
It's not a sealed box, and the rubber feet aren't just for vibration - they keep it elevated for air movement and out of puddles
Old Jan 9, 2007 | 07:51 PM
hip's Avatar
hip
mine is mounted on a flat piece of sheet metal with edge turned up & screwed into firewall, just to the right of brake booster
Old Jan 13, 2007 | 09:22 AM
LD85's Avatar
LD85
Old Jan 13, 2007 | 07:21 PM
cemittar's Avatar
cemittar
NitrousSam
X 2
Old Jan 13, 2007 | 10:49 PM
Road Agent's Avatar
Road Agent
The best place to mount it is on Someone else’s car!!
To Mounting MSD Box
