Diacom + new laptop without parallel port
Old Jan 9, 2007 | 05:08 PM
adi4's Avatar
adi4
Default Diacom + new laptop without parallel port
As the title says I have had to change my old trusty laptop for a newer model and when it turned up it had no parallel port
I have heard that you can buy a USB to parallel lead , but the question is will it work, I have spoken to Rinda but they are not sure and said that they will have to get back to me, so I thought that I would post my little problem here to see what you guys think
TIA
Adrian
Old Jan 9, 2007 | 06:35 PM
Trog's Avatar
Trog
I know Moates ODB1 in USB works for me after I moved up. No idea Diacom software though. I'll be to hear though.
Old Jan 9, 2007 | 07:36 PM
adi4's Avatar
adi4
What software are you using?
Old Jan 10, 2007 | 02:15 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Adrian,
I've been using Diacom for many years and have found nothing but problems with newer computers, even those with parallel ports. I have a several year old COMPAQ Presario 17XL365 with 700Mhz PIII that works and that is the fastest I've been able to get connected. My Toshiba Satellite with 2.4 Ghz PIV will not. The software obviously runs, just no connection. I've gone so far as to create a DOS boot disk with Diacom installed and still can't get a link.
So I guess, you'll have to suck it and see. I've never tried a USB-Parallel converter with Diacom, but if my past experience is anything to go by, if the machine is faster than 1 Ghz you may be out of luck.
Please post your findings.
To Diacom + new laptop without parallel port
