94 LT1 H20 Pump
Old Jan 10, 2007 | 06:40 AM
C4TOMCAT's Avatar
C4TOMCAT
Default 94 LT1 H20 Pump
Can anyone direct me to information on rebuilding an LT1 water pump.
Looking for the pump shaft seal part number and bearing number for the pressed in bearing. Also, how does one get the impeller out and any replacement parts needed. It looks fairly simple and I am in the process of rebuilding the engine and want to do the pump while it is off..or at least give it a try. part numbers of the following would help.
1 pump shaft bearing
2 pump shaft seal (back of pump)
3 how to remove the impeller & shaft
thanks in advance as I don't want to just ruin the pump if possible.
Tom
Old Jan 10, 2007 | 10:20 AM
STL94LT1's Avatar
STL94LT1
Even though I know the LT1 water pump can be rebuilt, I've yet to see anyone on this forum rebuild one.
Let us know how it goes.
-Mike
Old Jan 10, 2007 | 11:14 AM
C4TOMCAT's Avatar
C4TOMCAT
Thanks, I will if I gather enough info to attempt it. I wish I knew if the shaft/impelles is a slip fit with a snap ring holding it in or pressed in. I have not pulled the rear shaft seal out yet to see the backside. maybe this weekend...I will wait to see if I get some insight here on the forum.
Old Jan 10, 2007 | 11:23 AM
STL94LT1's Avatar
STL94LT1
The shaft is pressed in.
Old Jan 10, 2007 | 09:06 PM
JTHVETTE's Avatar
JTHVETTE
Default LT1 water pump rebuild ????
I started to rebuild a water pump for an LT1 several months back. I put the project on hold for a while, due to lack of time. If you are really interested in this, I will see if I can find all of the info. I had gathered on this project. In my opinion, these pumps are built in a way that they are going break down sooner or later. After taking a close look at one, I believe that they can be rebuilt to last much longer than normal, with a simple modufication.
My 2 cents,
JTHVETTE
Old Jan 11, 2007 | 06:09 AM
Casethecorvetteman's Avatar
Casethecorvetteman
Punch the guts out of it and plug the hole, screw on an electric unit.
Old Jan 11, 2007 | 07:59 AM
94z07fx3's Avatar
94z07fx3
It seems like I remember someone talking about drilling out the drain hole and tapping it and installing a nipple so a hose could route any future leaks safely below the opti. I do not remember if he actually did this or was musing.
Old Jan 11, 2007 | 08:15 AM
Casethecorvetteman
Yeah mate someone did that a while back
To 94 LT1 H20 Pump
