Possible low idle problem
Old Jan 10, 2007 | 07:48 PM
EvanD's Avatar
EvanD
CF Community Team
Default Possible low idle problem
I might have a problem starting.....
A few weeks ago I drove to West Virginia, 600 miles, to visit my son. It was wet most of the trip, rain or fog or both. After the visit it was nice and sunny and when I started the car, 92 coupe 6 speed, it wouldn't idle well, running about 4-500 rpm. As long as I kept the car going it ran well, it was just an idle problem. After the car warmed up it got better, the high idle while rolling functioned as it should. The next morning it did the same thing. The morning after that it was fine, started idled at 900 or so and idled at 1200 while the car was rolling. Hasn't had the problem again until this morning. A cold but sunny day and the car would barely run 4-500rpm until it warmed up and then it was fine. I would say that the idle up function is not working but it's idling lower than 900. No codes or lights, all gages look good.
Any ideas? vacuum leak? Injector starting to go?
Oh, I forgot, this was just after putting Seafoam in through the intake and 3/4 of a can in the full fuel tank.
No throttle body on an LT-1...
Old Jan 10, 2007 | 07:54 PM
evmlarry's Avatar
evmlarry
Maybe spend a few bucks on a bottle of throttle body cleaner, toothbrush, and a gasket. I had some idling issues, pulled mine out and did a thorough cleaning of the IAC and TB. I went ahead and performed the steps to reset my idle and my TPS (I had my TB completly apart) and now it runs like a charm.
Old Jan 10, 2007 | 11:15 PM
MikeC4's Avatar
MikeC4
all FI LT1's have a throttle body! The FI delivers the fuel, the TB delivers the air!! Unless someone dropped a non-FI carburated engine in your '92. The above suggestion of cleaning you TB sounds like sound advice. You could have carbon buildup on the TB shaft which makes it stick at colder temps. I would also take a wild stab at a bad O2 sensor, but that would throw an error code. Next, I would run my tank to about 1/8 full, then load up on premium gas, see if that clears up your erratic idle.
Old Jan 11, 2007 | 07:22 AM
RRT vette's Avatar
RRT vette
Remove the throttle body....the IAC and clean both.
Old Jan 11, 2007 | 11:20 AM
EvanD's Avatar
EvanD
CF Community Team
OK I know there's a throttle body, I was lost for a moment thinking about my Camaro that had a throttle body that was like a carburator...
OK clean that and the IAC. The IAC makes a lot of sense as when I did the Seafoam it could have washed junk down stream...
Now all I have to do is figure out where it is....
Thanks!
Old Jan 11, 2007 | 11:24 AM
RRT vette's Avatar
RRT vette
The IAC is on the bottom side of the throttle body. I would recommend either using the old gasket if in good shape or making one from gasket paper. Use "throttle body" cleaner on both and a toothbrush or small brush.
Old Jan 11, 2007 | 11:49 AM
SunCr's Avatar
SunCr
Idle speed is a function of engine temp. Scan it to see what the ECM is receiving from the Coolant Temp Sensor. On a cold engine, the temp reading should be about the same as the outside air temp. Otherwise, spend 9 Bucks on a new sensor. Check it's resistance cold and then check the resistance of the installed sensor. Both should be close. If not, simply plug the new sensor into the harness and start it. If the idle is correct, replace the sensor. If the resistance of both sensors are close and if the idle speed is still whacked out with the new sensor plugged in, that might indicate a faulty ECM. A clue would be if the fan is running with the engine cold and the a/c off. A scan would provide greater certainity.
Old Jan 11, 2007 | 11:59 AM
EvanD's Avatar
EvanD
CF Community Team
Thanks! Looks like I have some things to clean and check....
Old Jan 11, 2007 | 12:20 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Check your PCV valve also. They tend to get neglected at tune-up time. Cheap fix and preventive maintenance, too.
Old Jan 11, 2007 | 12:58 PM
EvanD's Avatar
EvanD
CF Community Team
What would a PCV valve cause, I ask because I did drop mine just before this started...
Today it starts and idles perfect..... I'll go get some cleaner.....
Old Jan 11, 2007 | 09:12 PM
MikeC4's Avatar
MikeC4
here's a good, understandable writeup of the PCV's function:
http://www.misterfixit.com/intakman.htm
To Possible low idle problem
