Hypertech III Programmer - Good or Bad?
Old Jan 11, 2007 | 05:35 AM
wilsonbh's Avatar
wilsonbh
Default Hypertech III Programmer - Good or Bad?
I'm on the fence on getting one of these devices. Can get what I need on eBay for about $150 or so. Are they worth the expense? I do have need to change the fan speeds on my car and who knows what else!
Anyone have one of these they hate/love? Would like to know what you think...
Billy
Old Jan 11, 2007 | 02:24 PM
Dray's Avatar
Dray
Default Hypetech
Ok, I'll take a shot on a nickels worth. You will hear alot of pro and con, but it depends on what you what to do. I have one for my 94 LT1 and it accomplished what I wanted. I reset the temp for turning on the fans (nice), raised my speed limiter, raised shift point rmp and how hard i wanted it to shift and installed the hp tuning. It was pricey new from
Hypertech. But I am satisfied. Now, when you plug in a hypertech it will go and verify your Vin number and use this to verify that the correct unit is plugged in each time you use it. That said, if you not do use the same hypertech to return the car to it's OEM tune, the hyper tech is
locked to the vin number it was installed on. So with the Ebay one, try to confirm details before you purchase because if it's locked, it's not useable.
Dray
Old Jan 22, 2007 | 06:13 PM
moore299's Avatar
moore299
Dray,
Are you saying that if you return the car to the orignal tuning, then you can use it in another car?
Old Jan 22, 2007 | 07:11 PM
STL94LT1's Avatar
STL94LT1
Yes.
Old Jan 22, 2007 | 07:43 PM
hgh pwr's Avatar
hgh pwr
I use one on my t/a , and it works well depending on the mods you plan on doing later. Light mods it is worth it, heads and cam I would pass.
Old Jan 22, 2007 | 07:49 PM
Rich96c4ce's Avatar
Rich96c4ce
It did what I wanted: changing rev limit, shift points, temperature, octane, and shift firmness. This winter, it will allow the computer to know that I installed a 3.75 axle ratio. Its a nice tool, but as others have said, limited to a mostly stock engine set-up.
Old Feb 3, 2007 | 11:33 PM
byedan's Avatar
byedan
can you feel the power difference or just the transmission shifting better is there a e.t difference?
Old Feb 8, 2007 | 01:34 AM
Eddie & the Cruisers's Avatar
Dray
If you purchase a used one, call HyperTech and they can tell you how to reset it.
Old Feb 8, 2007 | 06:11 PM
hgh pwr's Avatar
hgh pwr
I installed one on my trans-am ,stock it ran 14.36 and with the hypertech it ran 14.10's.
To Hypertech III Programmer - Good or Bad?
